Lubricating a DC Maytag
The top tub bearing should only have turbine oil used, lithium grease is too thick, the brake should have transmission oil in it only.
If you don't replace the transmission you are doing a lot of work for a washer that is only going to run a year or so at best till you have water leaking into the top spin bearing or into the transmission.
