cfz2882
just got a 1999 neptune mah3000aww in non-working order,but
very good cosmetic condition for $25 from a 2nd hand store-
seller got it from abandoned storage and tried it-said it
filled up,started to tumble,timer did not advance,door then
popped open and flooded his work area.
I tried it and found:
-starts to tumble as soon as turned on
-fills up to the center of the drum then shuts off-"on"light
turns off-center of drum way overfilled?
-"door lock"light does not come on
-will drain but will not spin if timer manually advanced to
spin (timer does move so motor working)
-feels like something in outer tub is rubbing/catching on drum
(bearings are good and no axial or radial movement of drum)
-inspection of control board revealed a resistor next to a
gray capacitor burnt and a transistor badly overheated-did
not test the transistor to see if it was bad.
Does this sound like "wax motor"related problems?
What could be rubbing behind the tub?
