Ok great, thanks! I’ll check the drain hose isn’t kinked and I’ll make sure it is the filter that is leaking. And then it looks like I may well have a little project on my hands to remove the inner wash basket and replace the filter. I just have a couple of questions, so that I can prepare for this, as I’ve never even removed an agitator before, let alone a tub!
What kind of tool should I use to remove the agitator nut/screw?
Should I heat up the agitator with a hairdryer and then try to pull it out?
What kind of tool is required when undoing the nut that holds the filter in it place?
All hints and tips greatly appreciated.
