Soooo.
I picked the Bosch up last night. My father-in-law gave me a lift. It was very heavy! It was missing the drain hose so i fitted a new one and gave it a clean up! The plumbing under our sink is really awkward. The taps are on backwards in between the sink pipes and access is really restricted. I was going to connect it via a y-piece to cold but it was too awkward and the pipes are quite thick. So i connected it hot and cold!
The machine has a big scratch down the side which in time intend to spray paint. I ran a cloth over it and tried it out. The motor was abit growly at first. It is obviously noisier than the old crappoint. But its an acceptable amount
So by the time i had cleared it out it was getting late & called it a night. In the knowledge the machine is fully functioning.
Today. I got home & tried my 1st cycle! I did some darks on cotton 30 with ariel excel with higher water level option and short wash option.
So the programme with higher water level acts as follows:
The machine starts off a low waterlevel with slow tumbles. Then it goes to faster tumbles for about 5-10 minutes. Then it fills into the door seal and continues washing with fast tumbles and short pauses. The 3d aquaspa works really well the asymmetric paddles really throw loads of water over the load!
The first spin after the wash:
(A note to construction....It never rebalanced once for any of the spins throughout the programme!)
I'm not sure of the speed think it was about 500 or so. The machines drains completely then goes into a steady distribution with a gradual increase in speed in one constant spin.
Then one of my favourite points is as it slows down from the spin the cascade in the door seal sprays as it spins and slows down!
Rinsing: The machine then filled with the cascade and each rinse has the "guarenteed rinse time" Irregardless of the fill time, the machine will rinse for the set time. The water filled into the seal for the first rinse. All rinse tumbles are a really good speed so as not to make more suds.
The same spin repeats. 2nd rinse was about 3 inches up the door.
in total 4 rinses applied to this wash with higher water level.
Now just as i was thinkin how much i liked the machine....it slowed down from the spin filling through the cascade. then as the drum stops the machine just fills from the bottom with slow tumbles. heres what i wasn't prepared for...a SUPER high logic style final rinse!
Final spin: Long steady spin up to about 800 for a few minutes. It stopped redistributed and accelerated with speed up to 1000rpm!
All in all the wash took about 1hr 10. Everything is washed and rinsed perfectly!!
Pics to follow!
Darren
