beekeyknee
My Mother gave me this last Christmas. It belonged to her mother. My Mom took it to a clock repair guy and he put a new cord on it but that's all he did. I had to shake it to make it start running, so I took it apart and sprayed some Tri-flow spray into the escapement. That helped it for awhile, but the motor is worn and noisy. It has a copper encasement with a little pinion sticking out of it. It's a little induction motor with a smaller round raised portion protruding from the back. That's where the rotor is and it pushes down into a laminated field coil. There's no direct electrical connection. There's a motor escapement inside the case that drives the pinion. I suspect the gears are worn and/or need lubrication. I guess I will try and find a strategic location and drill a small hole in the case to introduce a little lubricant. I will have to make my best guess as to not hit anything important on the inside. A dentist drill would come in handy about now. The second best idea I can think of is a small bit on a Dremel Tool. I'll have to go slow. On the back there is a partial label that reads, General Electric Kitchen Clock. Model 2H08. Someone wrote the date 2/9/55 on the label. I would post a picture of the motor, but it's in the clock and I didn't feel like taking it apart right now. It's a cool clock. When the power goes off a little red dot drops down to let one know the clock needs to be reset. One like it was in the movie, Driving Miss Daisy. I found this post on ebay of someone trying to sell a clock like this. He says it was supposed to be white, but this one is green and I know it hasn't been repainted. The one in the movie was the same green color. I remember this was a common color in kitchens back then. He sounds full of it to me.
Now that I have been looking around, it seems they came in several colors.
[this post was last edited: 5/10/2014-01:14]
