My KDS-18 has sprung a leak. Help!
Marky_Mark
Aug 3, 2014
690
Living in Palm Springs and Madrid. From Liverpool.
Hi guys
My KDS-18 has never given me any problems until today.  I started the machine and the tub filled normally but all the water leaked out over the course of around 5 minutes.  The bottom of the motor is full of water and it appears that water has been sprayed all over the place by the motor.
The machine had been sitting in my unoccupied house for a month -- hot and dry with the A/C off.  I thought the seals may have dried out and would re-seal themselves but so far it's still leaking like a sieve.
All thoughts appreciated!
Mark
Main seal leaking on the KDS 18 dishwasher
Hi Mark, hopefully that should be an easy repair things like this to fail.
Seals do not dry out and fail, but it could have gotten stuck from sitting and just torn itself apart when it went to run, not a bad repair take the pump apart, carefully replace the drain impeller and seal. Hopefully you’ll be good to go.
John
