My mum's Bosch slimline DW suffered a catastrophic PCB and pump failure.
Parts would have been 250€.
But she's moving to my late grandmas flat once that has been renovated - so next year probably - and will be getting a new kitchen at the same time. So she decided to get a cheap replacement instead. That way she has warranty on it until she gets her new kitchen and dosen't have to worry about it.
As the DW market is in a pinch currently, she just got a cheap store brand machine.
It's branded Hanseatic and from the looks of it made by Amica.
It's nothing special, biggest requirement was noise.
It got delivered today, delivery team refused to take the old one with them even though be payed for that service.
So currently working on getting that refunded.
Fitting the Bosch was a breeze.
Fitting this was a nightmare.
One of the front feet was locked up. So I had to chew into the sift plastic to be abled to grip onto it enough to screw it out. So that foot is broken basically, but it still sits level on it so what ever.
The machine came with one of these crappy foil steam protectors for the underside of the work service, so I kept the metal one from the Bosch.
That ment I had to fix the DW to the cabinets instead of the work top.
The screws provided are just to short to fit them through the holes and keep them on the screwdriver.
Luckily the ones from the old one weren't to long to use.
Still had to predrill the holes.
The side profiles intended to stick to the machine to bridge the gap there of course don't stick well and come loose, but what ever.
Fitting the front actually is quite easy compared to the rest of the procedure.
I ran the machine through an intensive cycle with quick.
It can run both spray arms at once as well as seperate and for quick it ran them simultaneously all the way until the last few minutes of the final rinse.
It has an automatic door opening at the end of the cycle.
Unfortunately they omitted the sprayer from the top of the cabinet since it doesn't have the cutlery tray.
And they added a super annoying beeper you can't switch off.
But we'll see how it cleans!
