philr
Back in the 1960s, the instructions on these mowers suggested that we mix SAE30 oil in the gas in a 16:1 ratio. The instruction manual from my father's former 1975 19" solid state ignition mower suggested to use OMC 2 stroke oil in 32:1 ratio or other brands in 16:1 ratio. I'm wondering if they lowered the mix ratio because of improvements in the engine lubrication or because of the new two stroke engine oil? Older "C" and "D" motors had 3 piston rings instead of two until somewhere in the early seventies and I don't know exactly when they switched from crank bushings used in all the "C" engines I have seen to needle crankshaft bearings but I'm guessing it's in the "D" engines. I really like the older motors with the recoil on top (or no recoil at all!) and a choke instead of a carb primer as they are usually easier to start but even the 1976 mower (with a primer bulb) I got from Roger is easy to start.
Tim, was your's featured on this ad? The guy who sold me my 1957 Control Tower washer/dryer set had sold a green 18" Lawn Boy "special" mower just like the one with a green handle in this ad to someone else I know just a week before I got my washer/dryer set.
