danemodsandy
Rust on Porcelain:
The easiest and best way to clean rust from porcelain - and also the exposed metal - is ZUD Cleanser. ZUD is formulated to remove rust stains from sinks, toilets, etc. You can find it in grocery and hardware stores, somewhere near the Comet and Ajax.
If you will use ZUD on the rusty places that are chipped, they will come completely clean. A little clear lacquer applied with a brush on the bare metal will keep rust from re-forming for quite a while. When it does re-appear, a little lacquer thinner will remove the lacquer, and you can repeat the ZUD and lacquer treatment.
I would respectfully disagree with Kenny on the use of a green Scotchbrite pad; I find them too prone to scratching and scuffing surfaces. I use the blue, non-scratch Scotchbrite pads, with excellent results. I don't disagree with him on the use of dishwasher detergent!
A question - how in the HELL did you move that thing in a Mazda 5 minivan? Did you lay it down? If so, I hope you gave it some "upright" time before plugging it back in.
