Trappn & Mike, thank you both for the comments. I realized the AI was locked into med. hi temp. that's actually the same temp as on towels. But I wanted to try it. The comforter was dried on Bedding, which is medium. I haven't worn any of the t-shirts or the wrinkle-free shorts that were dried Tuesday yet to see if anything shrank. One thing I forgot to mention was right after the installers left, I wanted to see just how sensitive the sensor was when empty. After tumbling on heat for two minutes, the dryer went to cool down. And it did that on all the cycles I tried so that I'm pleased with. As with the electronic control Maytag, I could start it empty on normal dry and it would take 10 minutes to get to cool down, very dry was at least 15 minutes. I had hear a long time ago that these modern electronic dryers are sensor controlled when it comes to cool down, it stops when drum temperature reaches at certain temp and stops. Well, things are still quite warm as far as I'm concerned. I will say the cooldown for the load of towels was about 7 to 8 minutes, but it hung on the 1 minute for those extra minutes. Also when it was still drying and was getting ready to change from 6 to 5 minutes, dry time was upped about 15 minutes, but in the end it was sonly about 12 minutes before it went to cool down. As far as I'm concerned, stopping the dryer before the inside is totally cooled down is wasted energy that should be used to finish drying the load. These days since I'm no longer working, I don't have slacks or shirts that have to be hung up out of the dryer. If I did, I'd probably use the app to switch the dryer to air fluff once it reached cool down.
Mike, thanks for letting me know about the temp when using ex hot on Normal. I would imagine it's similar if selected using Heavy Duty. I wish we could find out if on AI wash cycles, if the tumble patterns are impacted if user reduces spin speed from the default of the setting of Whites or Normal. AI is also "present" when selecting rinse & spin.
