Duet vs. KenLG
Our 41982 Kenmore built LG is significantly quieter while running, except for when filling. A lot of the newer TurboWash 360 machines have fixed this. Our Duet was an older model with belt drive and struggled with balancing. It did have some vibration issues as a result. One odd thing I noticed with the Kenmore was that it will not fill with both hot and cold water valves at the same time. The Duet would, and was very accurate with water temps. The Kenmore frequently fluctuates water temps by quite a bit when filling, but is fairly close once full. The Kenmore does suds lock significantly easier than the Duet. I think the Duet only did twice. That one I can't explain.
In my use with the Kenmore, the Normal cycle tumbles at a higher speed, tumbles less frequently, and with a longer wash period when NOT using TurboWash. It also uses a higher interim spin speed and much lower rinse water levels. I personally prefer all of these things except the lower rinse water level. My biggest gripe when TurboWash? The interim spin is not nearly fast or long enough. The fact that the drain pump does not run when it ramps down just adds to the effect because the extracted water remains in the pump. At least this is how my Kenmore and the WashTower that a relative has. Hence, why I typically do not use TurboWash. But again, that is my personal experience.
The final spin regardless of selection is too short, IMHO. It will ramp up to 1255 rpm and instantly slow down to call it quits when HIGH spin is selected. Extra High will spin at 1100-1255 for about 8 minutes. Far more effective.
appnut, I fully agree that I do not care for the DOE forced temps. These machines are efficient enough. If I want a Warm wash, damn it, give me a warm wash! Our Duet was spotless after 10 years when the bearings went. I attribute this to tap hot and true warm washes when using the Whites cycle.
The Kenmore would do a ~110ºF wash with Hot on every cycle including Whitest Whites. With ours, it did NOT heat the water or even maintain that temperature on any cycle. In fact, the only cycles that do heat the water or maintain a temperature are: Heavy Duty-Extra Hot,Normal-Extra Hot, any time Steam/Steam Treat is activated, Allergen, Sanitize, Speed Wash, and ironically enough, Normal-Cold. Normal-Cold would always fill at around 70ºF and heat to 74ºF, which really made me happy.
Our Normal-Extra Hot always would heat to 149ºF. It would be higher with increased soil level. The highest I ever read was 158ºF.
