spacedogb
Hello everyone,
I was recently able to get my hands on a set of touchscreen neptunes. The guy i got them from said they had been outside for about 2 weeks, the rust on them leads me to believe a lot longer time than that. Also he told me the washer worked and the dryer made lots of noise. I was able to plug in the washer and here are the problems i have run across:
The screen is out and the LCD has bled through. He said he tried to heat it up with a hair dryer to correct the problem.
There is mold EVERYWHERE!!!! (I plan to take the washer apart and clean every inch.)
There is rust all over the cabinet (I want to take it apart and have the exterior refinished)
When i plug the unit in and connect to water, I get two short buzzes and the unit does nothing else. (Any ideas what it may be?)
When I turn the tub inside, it sounds like something is rubbing and grinding like bad brakes. (Bearings?)
Any help or suggestions would be greatly appreciated.
