perc-o-prince
Hey all,
So we found this fridge at an estate sale where people were let in one at a time by appointment. The power cord was crispy-critters, so I'm replacing it with an 8' replacement 2-wire 16 ga. cord. Meanwhile, I realized that the wires to the compressor are also crispy, and the relay-end of the wires to the thermostat are the same.
I'm considering replacing the wires with what I have on hand. From the relay to the compressor, 14 ga. solidor 16 ga. stranded. From the relay to the thermostat, I'll probably splice as the wire seems pretty flexible toward the top of the machine where it enters the cavity. Probably 16 ga stranded.
Thoughts? As you can see, this unit draws a bit less than 2 amps.
Chuck
Chuck
