My Rubber Molding Skills Saves My 1953 Apex Wash-a-Matic!
Unimatic1140
Administrator
Staff member
Apr 26, 2001
10,129
Minneapolis
So I was doing a load of wash early last week in my Apex and when the load was done I noticed there was a stream of water was running out the bottom of the machine. So I took off the machine's lower skirt panel to investigate and sure enough water is leaking out of the safety valve.
The Apex safety valve has three functions:
#1 to fill the water clutch with cold water to raise the spin clutch pad and shift machine from wash to spin.
#2 to drain the water clutch when spin is completed which lowers the wash clutch and tub brake down to stop the tub from spinning and shifts the tub back into wobble wash.
#3: There is an unbalanced load sensor activating pin on top of the safety valve that quickly drains the water clutch to momentarily shift the washer from spin to wash incase of an unbalance load. This causes the tub to stop and wobble for about 1 second to try to redistribute the wash load and then it automatically shifts back to spin to try again. It keeps doing this over and over until it automatically balances out the wash load.
There is a rubber diaphragm that seals the activating pin that has cracked open and gone bad, being over 72 years old it's amazing that it lasted this long. So I took the safety valve apart and found this diaphragm has split open and cracked. I had one in tact diaphragm in my parts stash but it's center hole has stretched open too wide to seal properly and it's hard as a rock. But thankfully it made a perfect model to make a mold out of, all I had to do was fill in it's too wide/stretched center hole with clay and mold it like that. After I have the new rubber part I used a simple hole punch to make a smaller/original size hole.
I'm happy to report the machine is back together and running perfectly again. After nearly a dozen loads there is not a single drip coming out of the safety valve, my new part works perfectly and I couldn't be more thrilled!!! I made several of them in pretty colors for backup but I sincerely doubt the new one I put in will ever need to be changed again during my lifetime.
A brilliant repair, thanks for documenting it for us.
What an ingenious mechanism, using water pressure to engage spin, and releasing the water pressure if out of balance.
Do you know what the minimum water pressure is? I wonder if it would work on my gravity feed water supply?
(normal washing machine fill valves work OK but fill a little slower than on mains water.)
Great job on the reproduction.
Hopefully tech will come around make the repro process much simpler and quicker than the labor intensive molding process. It would be nice to "print" one of these in a few minutes after a quick scan.
Thanks everyone for all the kind words, I'm thrilled to be able to fix this properly. I probably should have learned to do this sooner, but I don't think the chemicals were anywhere near what they are now.
Hi Chris, according to the service manual it states 'Required water pressure is 10 lb. flow pressure, 15 lbs. preferred. Volume must be at least 2.6 gallons per minute.'
That would be a dream come true Dan, the way AI is rapidly advancing I wouldn't be surprised to see that by the end of the decade.
