my Naco is fully working, motor rewound, bearings replaced, and all seals when possible have been replaced, I'm gonna water test it tomorrow and i finally got the spin belt replaced so it spins as well as the belt tension is adjusted properly
it isnt entirely sealed as water leaks out of the weep hole but it looks really good
ill have to grab some photos later as the machine is having a live casing issue
i had to use a second Naco as the paintwork was much better on that one and it had a motor as well but its finally complete, ill grab photos in a minute
My aunt had one of these in the fifties. It definitely had a red hopper lid/cover. I think the cabinet was white. It was replaced by a Bendix Gyromatic in about 1962
The spin belt - look at Poly-V belts. (link below) The original was possibly a leather belt?? These clutch nicely, better than modern poly-V belts. I think your current serpentine belt (which is a type of poly-V) is too large diameter? I have just done a quick search, it appears true flat belts are still available, I have linked one below.
The video doesn't really show what happens to change to spin, does it work by lowering the motor to tension the spin belt?
yes it lowers the motor to engauge the flatbelt on the pulley, and it is about the same dimentions as the old leather belt, ill chet out that link, thanks
#53 I have no idea why it got replaced. I would have been six at the time. It's possible it came with the house my aunt and uncle purchased, so had perhaps seen a good life before they came along. They were a family of three kids under eight too, so lots of washing. I guess the idea of a Bensix Automatic was just too enticing!
That's according to the brochure I've attached (I think I downloaded this brochure form the archives here on automaticwasher.org. I hope it's not a problem to re-post it here)
The Australian version that my aunt (and later ourselves) had was cosmetically a little bit different from this, however the engineering/mechanical side of things was identical
