The dilapidated machine is long gone
I know it doesn’t look that hard to find a motor as it has standard mounting bolts for a normal motor, compare to today’s modern washing machines as they have custom mounting for their motors, the only thing I’ll probably have trouble getting is the pulley for it as the pulley needs to accept BOTH a flat belt and a V belt, i’ll probably ask for some help in here and if worse comes to worse I could probably have someone turn a pulley in metal or wood So this is much less of a loss than it actually seems Compare to a vehicle with no engine, thank you for standard motor fittings, I might already even have a motor for it Roca to a motor shop And ask if they have any 1/4 hp motors as that’s what the machine uses
