Naco washing machine
Thankyou. The fan shaped slots in the bottom of the tub force water into a false bottom of sorts, creating pressure that forces water out of the central drain pipe that runs through the centre bearing. The lever on the back is to pinch the drain hose closed.
I’ve never had it running as the motor is seized, but that rubber wheel rubs on the inside of the washtub.
I have no idea how fast it spins, but with no suspension and that pole in the way, I can’t imagine it’s fast.
It shows up from time to time in the Patent of the day.
That is great, Adam.
The spin belt - look at Poly-V belts. (link below) The original was possibly a leather belt?? These clutch nicely, better than modern poly-V belts. I think your current serpentine belt (which is a type of poly-V) is too large diameter? I have just done a quick search, it appears true flat belts are still available, I have linked one below.
The video doesn't really show what happens to change to spin, does it work by lowering the motor to tension the spin belt?
Poly-V: https://www.naismith.com.au/upload_pdfs/239-149896226256553117baaa9.pdf
Flat belts for vintage cars: https://www.gates.com/us/en/power-transmission/v-belts/flat-belts.html
#53 I have no idea why it got replaced. I would have been six at the time. It's possible it came with the house my aunt and uncle purchased, so had perhaps seen a good life before they came along. They were a family of three kids under eight too, so lots of washing. I guess the idea of a Bensix Automatic was just too enticing!
9 pounds/4 kilograms
That's according to the brochure I've attached (I think I downloaded this brochure form the archives here on automaticwasher.org. I hope it's not a problem to re-post it here)
The Australian version that my aunt (and later ourselves) had was cosmetically a little bit different from this, however the engineering/mechanical side of things was identical
Wonderful machine
