The dishwasher had a few problems that needed to be fixed. It only would fill for the first rinse, so I opened up the timer and I sanded down and spray cleaned the fill contact, works perfectly now. The pump was leaking which is now fixed and I installed a stronger return spring on the pump so it presses the pump pulley against the rubber motor rotor with greater pressure. If found, just like John did, that if the pump got wet it wouldn't pump very well, but the stronger spring seems to help quite a bit.
Terry the Westinghouse is installed downstairs in my workshop. I installed a row of cabinets with a Formica worktop and two 24" slots with plans of someday installing two dishwashers in there. The Westinghouse is the first to actually be installed in that area.
Steve I thought the same thing about stainless steel racks that you have to load more carefully as not to chip anything glass. But that's a small price to pay to have absolutely perfect, defect free, 55 year old dishwasher racks. When you close the draw the floating metal lid in the ceiling of the dishwasher comes down locks against the big rubber gasket around the top of the dishwasher tank.
The cycle is:
1.5 min drain
1.5 spray rinse
1.5 min drain
45 sec fill
5 min wash
2.25 min drain
45 sec fill
45 second rinse
2.25 min drain
45 sec fill
45 second rinse
22 minute dry
Tom if I would tinker with the cycle of this dishwasher what I would do is get one of those adjustable bi-metal electrical relays. The relay works by opening and closing a switch at a manually adjustable time interval such as 30 seconds on and 30 seconds off. I would wire the relay in series with the timer motor, which would turn the timer motor on and off ever 30 or 45 seconds (or what ever time period I choose). This would double or triple the entire cycle time. I would probably open the timer up and shave down the dry cam so the heater is only on for twenty minutes and the rest would be a cool fan dry. The heater is only run during the dry cycle, but I would rewire it to run with whenever the motor is running, which would make this a great performing dishwasher for 1950.
But I’m probably not going to tinker with this dishwasher and leave it as Westinghouse intended it to be. BUT tonight I’m picking up one of my ultimate #1 dream dishwasher which probably will get tinkered with because it’s too cool to be such a bad performer.
More to come on that later on in the weekend.
