Need a good traditional apple pie recipe
Just got home and it was a huge hit! It turned out absolutely delicious! I didnt have any mace, so I used about 1/16 of a teaspoon each of nutmeg and allspice, and the recommended 1/2 tsp of cinnamon. I had planned on having a piece later, there were 3 slices left, but forgot to bring it home. I seriously considered driving 15 miles to go get it lol. I decided not to because it would likely be gone when I got there! I will definitely save the recipe and use it again!
Round Pies
My Hungarian guest wanted to do some baking one day and I suggested apple pie. I was busy doing other things so I didn't see the pie until it was out of the oven. It was huge as she had made it in my oval roasting tin. This was not a problem but I showed her my round pie dish, which is a similar size to that shown in #15 above. She seemed horrified at the thought of making round pies! Apparently pies are normally square in Hungary but she could not find anything square amongst my stuff. Pies are cut into squares, not angular wedges and our "pie chart" does exist in Hungary but is called a "tortadiagram" or "cake diagram", as cakes can be round!
Less is more. Raisins and nuts have no business in a apple pie. Nor does mace.
Try this 90 year-old recipe:
7 cups sliced apples. [Jonathans are best. A 3 lb. bag equals 7 C.]
2/3 C. Sugar
1-1/3 T. Flour [not cornstarch or tapioca.]
2 t. lemon juice
1/2 t. Cinnamon
1/4 t. Nutmeg
1/8 t. Salt
Pie dough. Duh. But pie dough needs lard, btw. And butter. But not corn meal.
425 F for 25 min, then 25 to 30 min at 350 F.
What I described isn't just Apple Pie, it's Dutch Apple Pie. There is a difference.
BTW, the Dutch Apple Pie usually has a cinnamon crumb coating on top rather than another crust. It's just another variation on a theme.
Has anyone ever tried substituting Pears for Apples in a pie? They have similar consistency. I wonder how that would turn out.
I used an all butter crust and used half nutmeg and half allspice in place of the mace. It turned out wonderful, and tasted just how apple pie should (to me anyway).
Pie crust problemo's
Kelly;
I always seem to have trouble rolling out the dough in a nice smooth uniform shape.
What happens is my dough starts to crack once I've gotten it perhaps 6-7 inches circumference. Do you think it's because it's too dry?
Everythings cold from the start, it sits wrapped in the fridge to chill, etc etc.
Taste wise it's good it just that I always end up having to do some patchwork quilting
It may be slightly dry, or, what I do to eliminate cracking; I roll it a bit, then smush the edges back in, all the way around, just push it back in, using one hand to keep it from folding, and the other to push. You will end up with something that looks a bit like a shallow crater, bowl, or dinner plate. Just make sure all the cracks have been smushed. Then roll some more, smushing again as needed. I usually need to do it 2 or 3 times as it gets thinner. Hope this helps (or at least makes sense!)
Pete, look at the equipment you are using.  I had those kinds of issue in the past, used the same rolling pin my mother and grandmother used.  I picked up a Wilton on clearance at Meijers a few years ago and it made the world of difference.  It's the type with silicon coating, and it's much larger and heavier than what I had been using.
A reminder of an earlier recipe
Can I just remind folks of Louis' supurb apple pie? Is was part of the drift of the subject thread which was about recipe books, you need to scrool down to reply #38 to find it. If you have not made it you should give it a try, it is REALLY good
Al
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?34973
Cracking
Cracking crust that's hard hard to roll can be one of three issues or a combination of them all. Stingy with the fat, using butter or not enough liquid. I most often use shortening, once in a while a blend with part butter but I don't make pies with butter. I use a higher ratio of fat to flour because it makes a very forgiving crust. The added liquid whether water, liquor, fruit juice or buttermilk insures an easy crust to roll and lots of flour for rolling. Before rolling gather the dough in a disc and press it into a circle. Using two sheets of waxed paper or parchment makes rolling a breeze. When you're done rolling lift off the top paper and flip the dough into the pan. Then peel off the last paper. Shape the crust and you're good to go. An old fashioned pastry cloth and stockinette work wonders once they're infused with flour.
Huge Devourer
of luscious apple pie, got to a point where I just had to make it faster, so I moved over to Phyllo (sp) Dough. What a win win that was. Quick, tender flakey crust with some parts crunchy, way way less fat& flour, still juicy, and like you Dustin, I use Macs, having grown up on them. They cook quicker and make lots of exotic syrup & nice clean apple flavor. Like cinnamon and sometimes nutmeg for spicing and no thickeners, preferring it somewhat runny. Rarely met a homemade apple pie I couldn't find something good about.
Kelly, last night I made two pumpkin and two mincemeat pies using your recipe for the crusts. By far the easiest pies I've ever made!
