captainmoody
- Joined
- May 22, 2006
- Messages
- 348
This is the other washer I saved from destruction at the recycler a while back. Although it works (the motor and pump), someone swiped the belt!
I have no model number to go by, as that tag was removed by Lowe's. My neighbor has (what looks like) the exact model as mine, and I used that model number to order the belt. It crossed to a GE WH08X10003, well.. no go on that! As you can see by the pic, it is too small, no way it will go on the pulley.
Sooo, I then tried a Frigidaire model number from a similar unit on Ebay, that part number was 1340510009. Nope on that too! As a matter of fact, even though the part numbers on the Ge and Frigidaire bags were not the same,the belts themselves had identical numbers.
So, here I am, out 60 bucks in belts and still nowhere!
The washer was made in October 2003, were there two different belt sizes for this machine? Help! Looks like I am stuck good on this one..
