And... Let the fun begin!
Pic No. 1: this is a microfiber cloth in a spring clamp that will hold the drum while I remove it, as seen in Pic No.2. Pic No. 3, 4: the back is removed and the wires to the cord and cycling thermostat are disconnected. Pic No. 5: drum removed, giving access to the timer, in Pic No. 6. Pic No. 7 this is the belt for the drum, which is in ok condition Pic No. 8: this is the motor removed from the timer. On the meter, the 1 . Means infinite ohms, so the motor is bad Pic No. 9,10,11: here are some numbers which may mean the part.
