Need help with DE50
kitty
Oct 21, 2013
197
I got a Maytag DE50 (porta dryer) with my A50 (porta washer) and no air blows out. Took machine apart, and here is the belt that dives the fan: Does anyone know where I can get a new belt? Please tell me if you can find one.
Saw one...
I saw a belt for the fan on Repair Clinic and it would be about $40. I really don't want to pay $40 for a little belt. If you could find one somewhere else, that would be GREAT.
Improvise
I improvised on one with an inner tube from an old tire and it worked except that sometimes when you start or stop the machine, it pops off. According to my thermometer, the exhaust temperature is around 154 degrees Fahrenheit. I'm guessing that the temperature in the drum is around 160 degrees Fahrenheit. Also, the belt is very shaky because it is rubber, and squeaks a little. Has anyone found one that I can get for a decent price? Again, that would be GREAT to have the proper belt for the machine.
Blower Belt For A DE50
There are companies that will custom make urethane belts for a fairly reasonable price, my brother Jeff got some pump belts made for our 29" KM combos.
The exhaust air temperature would be about the same as the temperature inside the dryer drum.
Me Too...
I need the exact same belt.
All other belts in the unit are made of rubber.
But the exhaust fan made of silicone that gets brittle and cracks.
Silicone fan?
On my machine, I believe the fan is bakelite, not silicone. I don't know about the belt material, it is kind of brittle. I don't know what the drum belt is made out of. THANK YOU THIS IS A LIFE SAVER. THNAK THE LORD FOR AUTOMATICWASHER!
Ok I get it now...
On mine, I have used two big o-rings for the fan belt and it works PREFECTLY. No problamos, so far. Anyway, thank you.
Urethane Belts
Thanks for the link to the vendor. It seems to be the achilles heal of both the DE50 and A50. I purchased a new belt for the A50 a while back, and the weld broke (OEM Maytag belt) and the urethane belt on the dryer now slaps the shroud all the time which is what it did before it broke as well.
John, where did Jeff get his urethane belts made, I remember talking to him about it the last time I was there but I can't remember where he said.
Thanks
Tim
Oh no... More problems
I was doing a load and set it for about 45 minutes. Came back about 30 minutes later and timer hasn't moved. Anyone know where I can get a new one?
And... Let the fun begin!
Pic No. 1: this is a microfiber cloth in a spring clamp that will hold the drum while I remove it, as seen in Pic No.2. Pic No. 3, 4: the back is removed and the wires to the cord and cycling thermostat are disconnected. Pic No. 5: drum removed, giving access to the timer, in Pic No. 6. Pic No. 7 this is the belt for the drum, which is in ok condition Pic No. 8: this is the motor removed from the timer. On the meter, the 1 . Means infinite ohms, so the motor is bad Pic No. 9,10,11: here are some numbers which may mean the part.
