Hi John: Yes It does have a removable lint filter trap that water circulates through when it agitates. No,the machine doesn't drain completely. After agitation It pumps out through the drain hose at the same time water circulates through the lint trap, but water level only goes down half way, then it stops with no spin. At that point the motor stops with no voltage at the contacts. Eventually it fills again (rinse mode?) Motor starts, agitates a bit, pumps out part way, does not spin and stops with a partially full tub. I also ran it with the wires disconnected from the suds saver valve but it didn't make any difference. The model # plate is hard to read but I can see 5021080 and JH16619. Also 120 and 9.8 which I assume are the voltage and amperage.I'm assuming this is a Canadian model. Appreciating all your help,John----Don
