New Bosch Dishwasher Model #SHPM78Z54N
eurekastar
Jun 21, 2018
514
Amarillo, Texas
I've been on the lookout for a new dishwasher in black stainless and finally scored this new Bosch with Crystal Dry.  The stove and refrigerator are both black stainless, and now, the ensemble is complete!  There is some slight color variation, but no one would notice but me.  The stove is a gas Samsung and the refrigerator is a Whirlpool.
On its inaugural run, the Bosch performed beautifully!  Using the sample of Finish detergent provided with the machine, I tossed in a crock pot with some baked on cheese and goo and it came out almost completely clean.  Everything else was spotless too.  And the Crystal Dry feature lives up to its hype!
I made this response yesterday, but it wasn't posted.
BobLoad certification.
I dislike the flatware basket. It takes up too much space. I saved my splittable baskets from both my previous Kenmore Elites and use those as needed. My suggestion would be to put as much flatware in the 3rd rack. The MyWay 3rd rack I hve has a flatware cradle on the right side taking up about 1/3 of the space. It can hold 16 to 18 pieces. With my coordination issue, it's not the easiest for me to use constantly. And I am still amazed how the dishwasher managest to clean each piece with each item spaced right next to each other and not skipping a space. I've had forks as foiled as yours in the photo come fully clean spaced right next to each other. I also found out measing spoons don't have to be fanned out either. Just almost dumbfounds me as to how it managest to get it all cleran. I've had one piece not get clean. It's a shame Bosch didn't include the splittable flatware bskets with this model. If I hadn't had my old dishwashers' splittable baskets, I'd have sprung for a set of the Bosch splittable.
@ appnut
I'd have to say that the flatware basket is one minor drawback.  My flatware is Ricci Impero.  The handles are rather large and won't fit into the narrow slots.  I had to use a box cutter and enlarge half the slots!  Other than that, it's performance is impressive.
Nice!
What cycle did you use?
I found that the Auto cycle with Sanitize worked great for 90% of loads. The Heavy cycle does use a higher wash temp, but actually has a shorter main wash period. I am VERY jealous that your machine has Crystal Dry. Does it have the Extra Scrub option?
@ vacerator
This machine does not have the Extra Scrub option since it came from Lowes; however, I just used the Auto cycle to see how it would handle all that gunk and it performed beautifully!
My default setting is Auto, Sanitize, and CrystalDry. Bone dry coffee mugs and all stains removed. I would like to think that adding Sanitize increases main wash a slight bit more. That combination yields a 60-70 minute main wash. For very light soil, even with a full load, I'll add the 1/2 load option and that reduces the main wash to 40-45 minutes. I've also been known to use the delicate option to reduce spray pressure because I have disposable food storage items that fly around without the option. PUtting said items on cup racks helps, but when I run out of psace with that, then the flighty items occurs. Since May I've used Heavy 3 times.
Auto wash time
My slightly older Bosch would wash for around 50-60 on Auto with Sanitize. The Heavy cycle would only be around 30-40 minutes, and ironically was the fastest wash cycle when using Sanitize. Heavy cycle also did not alternate wash arms during the main wash and while heating the water. I'm assuming both wash arms were active. That machine dried everything except for plastics, of course. I would always pack that machine as full as possible and it never complained.
Only recommendation I can make is to use 1 teaspoon of STPP in the main wash dispenser to keep hard minerals at bay!
Congrats!
I have the 878 version that does include extra scrub. I have only used this option for baked on items I didn’t want to soak and scrub. Though I feel it does a pretty good job even with out that option. This dishwasher has been by far the best dishwasher I’ve ever used. The crystal dry is amazing. I have young kids with lots of plastic ware and they come out dry. I can put them back together right away in the cabinets.
Heat Source
As I understand it, during the washing process, moisture is drawn into the chamber holding the zeolite granules.  When moisture comes in contact with the zeolite, it is absorbed by the zeolite and triggers a chemical process where the granules heat up.  During the drying cycle, a fan blows across the heated granules and into the dishwasher, thus drying the dishes.  The air is heated up to 176º F.  The 800 series also has an "Intense Dry" setting as well, which raises the final rinse temperature like lower tier models with the "Extra Dry" setting.  When that is on and combined with the Crystal Dry feature, even plastics come out remarkably dry!
Not quite
There is a heating element in the Chanel for the air right behind the fan.
During drying, water in the form of vapour is sucked into the chamber with the mineral.
The mineral has such a huge surface area that it basically forces the water to condense onto it.
When water condenses, a lot of energy is released.
That heat is carried away with the air back into the chamber to dry the dishes.
There is no chemical reaction, just physics.
During the first heating Portion of a cycle, instead of heating with the heater in the wash pump, the fan AND the heater in the air duct turn on.
That hot air drys the mineral.
The evaporated water is blown into the cool wash chamber where it condenses and the heat is transferred to the dishes for washing.
Once a certain time has passed or the water reaches a certain temperature the fan and heater are switched off and heating resumes with the heater in the wash pump.
Silverware in the Bosch dishwasher
I agree with Bob.  I don’t know how it’s gets the silverware as clean as it does because there are times I push it.  My goto selection is Auto, Sanitize and Extra Dry.  Mine was before the Crystal Dry option was introduced.  I periodically use the Heavy option is the dishes are really dirty but I don't use Heavy often.
We also have silverware that has very thick handles and the pieces are longer than normal, I think.  The longer pieces I place up front of the rack with the handles between the wider spaces.  The smaller pieces I place in back with the fork and spoon end in between the smaller idents.  Unlike Bob, I generally put the smaller pieces on every other one because we don’t seem to use as much silverware as some.  When I have a full load, I put them directly next to each other.
I'll share what I've observed that I have shared some with Henrik and some with Eurekastar. The following aplies to all cycles except for Speed60. Without CrystalDry when the cycles end, the end of cycle beeps just a couple of minutes after end of final rinse. Adding CrystalDry, the final rinse temperature is increased above default final rinse temp inended for the base cycle. For these cycles CrystalDry has the little fan run for 30 minutes. Adding the Intense Dry/Extra Dry, I believee the final rinse temp may be increased la litle bit more. However, the time the little fan runs is increased to 57 minutes. Deselting CrystalDry option , but still having Intense Dry/Extra Dry, the CrystalDry technology is still activated and final rinse temperature is still increased some and the little fan runs for 30 minutes. So that's kind of like "cool dry" option. With Intense Dry/Extra Dry, the final rinse phase is extended by another 5 minutes on Speed60 and there's a "dry" (dwell) period after the final rinse for 27 minutes vs. default of 5 minutes "dry" after the final rinse before the signal beeps.
I absolutely love the flexibility, I have run load once or twice due to lightweight disposable plastics not flying around, select Auto and options of 1/2 load, delicate, sanitize rinse, and eco. I love being able to dictate a good dry with all these options and still have a "short" ccle. With 1/2 load and or delicate options selected and sanitize & crystaldry, the main wash is reduced from 70 minutes to 35 to 40 minutes. I can get a short wash cycle with light to "normal" soil level 2:15 to 2:30 hours and all dishware is bone dry and I love it. My two previous Kenmore Elite dishwashers cannot compare due to energy star mandates limiting dry to "pulse" period with sanitize rinse & heated dry. there was NO heated dry. Made me mad that I couldn't get what I WANTED if that's the result I desired. It's just like when I wash clothes, 95% of the cycles I use, has the onboard heater turn on as defaaut to maintain or heat wash water temp. If I end up having to replace my Duet with an LG, a former member is providing me with information with what options allow me to have warm water temps of 90 to 100 degrees and hot water above the default 113 degrees. I want to make the choices, not the government.
Heater in the air duct
That glass heater has been replaced by a more traditional heating element right underneath the Zeolite container, which is, I suppose, less sensitive than the in-line glass heater.
Heating
So, correct me if I am wrong. The air is pumped over the Zeolite during both main wash and final rinse. The mineral releases moisture when reheated during the main wash which releases the moisture from the previous dry cycle. Not 100% sure how considering there will be moisture in the tub being pumped over the Zeolite when it supposedly is drying the mineral itself? Though, after the final rinse, the fan turns on and pulls the very humid air over the Zeolite, which “adsorbs” the moisture and releases heat as a result. The air entering the tub again supposedly is very dry and hot. Thus, increasing the rate of evaporation of water on the dishes. [this post was last edited: 10/6/2021-09:02]
Water never enters zeolite chamber. The fan and heating element turn during the wash to recharge/dry out the crystals. During the dry cycle, just the fan turns on and the crystals heat themselves up as they absorb moisture.
My SIL has a crystal dry dishwasher and they love it.
Cutlery trays
I was led to believe by Miele that if the handles on your silverware were too thick to go between the tines of the tray you turn them around and place the knife and fork between them with the handles sticking across the part that has no tines ... and long carving knives etc just went over the whole tray. Only issue I had was things like spatulas that would be facing down sometimes remained dirty.
Austin
