New coffee maker
do you time it from the time you turn on the heat or when it
Jaune-time your coffee from the time it starts perking at 1 minute per cup. I've always had good luck with this method.
Venus and Steve Thankyou.
Thanks to both of you, I am eager to try my c-50, think I will wait for the weekend. The drip black & deck. with a timer is nice on workdays. But I will sure have some Sunbeam vacuum this Saturday. Thankyou for the pointers. I will let you know how this goes. Venus both of my aunts had these pots during my childhood but I just could not remember how to use them. Mom was always an electric percolator kinda lady. arthur
Oh, great, another obsession
JUST what I needed!
All this talk about vacuum coffeemakers has me wanting one! And I haven't even received the cool Presto perc I just won on you-know-where!
I see the Sunbeams all the time when I look for Sunbeam vacuums. So tell me, Venus--how hard are they to use? Parts hard to find? (I seem to recall reading a thread about a scorched rubber gasket??) Do they need any tending? I like a coffeemaker that will attend to its very important business without intervention from me. For one thing, I'm not too swift in the AM and for another, the priority at that time of day is making the hair look decent!
veg
Well, I'd like one too, Veg
Veg-I would like one of those old stovetop Corys' in glass, as I know those old Sunbeams are hard to find( I do know they make great coffee). I think you have to watch them when the boiling water rises up the stem so the bottom pot isn't left empty on the burner. Maybe that's when you shut it off.
Arthur-I like the electric perc taste very well too. My folks, starting in the 50's had a Mirro-matic (with the classic old percolator design), then a GE Peek-a-brew, then a Universal, then a Proctor-Silex, after that I don't know I think they switched to auto-drip in mid to late 70's. I wondered since you live in New Orleans what your favorite coffee is? Anyone else rreadding this is welcome to input on this matter. This Bodum pot looks like it may be good.
David
Im a transplanted yankee, maxwell house for everyday, Community Coffee makes me feel WIRED.....:-)
C-50 filters
"Laundress once suggested cutting out the little round part on a regular paper drip coffee filter for use in the C-50. Here's what I do. Cut out the round, cut a slit to fit on the stem, and voila....a filter."
They make ready-made round paper filters for fitting in the baskets of percolators. I use these to get sediment-free coffee from my percolators that one normally only enjoys from drip or vacuum makers, and I imagine they would work fiue for the C-50 Coffeemasters. The brand I use (Brew-Rite by Rock-Line Inc., Box 1007, Sheboygan, WI 53081) even has a part that one can tear off so the filter fits into percolator baskets that are narrower than usual.
Thanks Kenmore 1978
Will look at the wal-mart and also winn dixie, do you special order those? Thanks again. arthur.
Making coffee
"My understanding is that a coffee maker marked "8 cups" would hold eight 6-oz. coffee cups (or 3/4 of a std. US cup which is 8 oz.)"
You might want to do an actual measurement to see what teh pot actually holds. My Corning Electro-Matic percolator states that their "cup" markings are 5 oz and I suspect that's the standard coffeemakers use. Usually the size of a "cup" is also stated on the carafes of drip machines, too.
"The drip black & deck. with a timer is nice on workdays."
It's easy to buy a timer to plug any maker into to make it timed like a modern coffeemaker.
Oh yeah, I love that jolt! If I werre a drug user, I would probably have to have meth. Glad I don't do that, since I crave the speed effect of strong coffee. That stuff would probably kill me!
My magnificent obsession!
Ok guys: here's the "scoop" on the Sunbeams......
Veg and David:
They have become my "Magnificent Obsession"! I have six of them: 3 C-50s, 1 C-20 and 2 C-30s. The Coffeemasters require just a tad more effort than a drip coffeemaker. First, you fill the bottom bowl to the desired fill line, i.e., 4,6, or 8 cups. Next, you attach the top (vacuum) portion. You can place the filter rod in the top portion either before or after placing it on the bottom (or serving) pot. Fill the top pot with ground coffee, place lid, plug in, and turn it on. In about 5 minutes you will think that you are reliving the great Pompeii eruption! The Coffeemaster then switches itself to "low". In about 5-10 minutes, the bottom pot will cool sufficiently to "break" the vacuum and allow the coffee to fall into the serving pot. After the "great fall", the top portion of the pot is removed, and.....(drum roll please) IT'S COFFEE!
A few words of caution, however....the top portion (and bottom portion too) is very hot! Be careful when removing it. There are special stands for these, but since I do not have one, I just stand it straight up in the drain of my sink. Also, (I think I mentioned this on a previous thread) the coffee is McDonald's lawsuit HOT. I swear, I can pour a cup, drive 17 miles to the next town, and it's still scalding!
Now...what to do with those grounds...I purchased a funky yellow plastic vintage ice bucket. I place the cooled grounds in there. When the bucket is full, I put the grounds in my flower beds. It kind of gives the plants a *jolt*.
As far as replacement parts, etc. To me the C-50 is the easiest to use. There are "ears" on each side of the vacuum pot. You just press them down to seal the two pots together. The C-20s have no handles and no ears so they have to be twisted into place from the top. Getting the top off after brewing is a pain because the dang thing is still hot. One must use a towel or risk permanent damage. The C-30s have a handle. They are easier to use than the C-20s, but I'm still partial to the C-50s.
Since I am not an expert, I may or may not be correct on this but I'm not sure if the C-20s and C-30s have removable gaskets. The C-50 does have a removable gasket. Not real sure about parts availability, but I have seen them on ebay.
As far as the meltdown of one of my gaskets....that was on one of those fussy Silex coffee makers. They are great to look at but require vigilance (note my lack of it). These are way too much trouble for me. For someone like me (type A personality, ADDHD, etc.)the Sunbeam C-50 is the coffee maker of choice. It is virtually indestructible. Oh, did I tell you that the coffee it brews would put a "Red Bull" to shame. I'm wired for days! LOL
Hope this helps
Venus
Who's enjoying a delicious cup of coffee courtesy of the C-50
:-D
More on Coffeemasters!
Arthur:
I saw Melitta Disc Filters (for percolators) at my grocery store today. They retail for $1.79 for 100 and look like they would work perfectly in a C-50. Just cut a slit in a disc to fit onto the filter/strainer rod. This would definitely save a lot of snipping time!
Pete:
They're mine!! All mine!!! Sorry to sound so crazed. Must be the caffeine. ;-)
Venus
venus. thanks.
Venus thankyou for all your input on the C-50, You have a very nice collection of vacuum pots. Thanks for posting the directions, and also the heads up on the melitta filters. That sounds like the most user-friendly idea. I will definately look for them. Thanks again and have a great evening. I will let you know how this works out. will post over the weekend. Arthur.
community medium roast-arthur!
It's what I use most all the time, but I have been known to break away and make the dark roast. I love a good strong but smooth cup. No bitterness. Love espresso, cap; french drip I've never made. Ever made french drip, with the little white porcelain pot in the warm pan of water? I also enjoy Starbucks although it's not from Louisiana.
Sunbeam Coffemaster Collection
Very nice collection Venus!I LOVE em!! Collecting the small vintage appliances is a great hobby to go right with the large appliances,or as a stand alone collection.
I have to confess,I am not a coffee drinker. I only use my Sunbeam about two or three times per year,and then it is used for company. I do like the way it makes all the racket as it boils the water! The Sunbeams are a coffee maker with a personality. I think anyone who is a coffee drinker,and loves vintage "smalls" should look for one of these old Sunbeams. They are fairly plentiful, are of great qualityand make great coffee(so I am told),and best of all,they are full of vintage FUN!
BTW wouldn't it be great if you found this service set to go with your collection? I LOVE the Art Deco design!
Venus-the coffeemasters are beautiful!
Venus- that's quite a collection of these rare, but well known pots. Seems like the people that owned them were more "upscale" than the average Joe who used a stovetop drip pot. Got any toasters? I always liked the one which raised and lowered the bread automatically-they were sunbeams as well. One big beautiful hunk of chrome!
Glass vacuum coffee pot
"My grandmother had the one with the glass vacuum section. No idea what happened to it. Hmmm, maybe it's still stashed somewhere in her kitchen cabinetry."
Time to make a raid on Granny's place!
filters
"Just cut a slit in a disc to fit onto the filter/strainer rod. This would definitely save a lot of snipping time!"
Probably won't even have to do that, since there should already be a hole in the center for the percolator tube to poke through.
FYI, there's also another type meant for percolators that is square and has holes in the 4 corners and a hole in the center. These work by placing the center hole over the percolator tube in the basket, adding the coffee, then bringing each of the 4 corner holes over the tube. This then totally encases the coffee within the filter paper.
"Will look at the wal-mart and also winn dixie, do you special order those?"
Available at supermarkets.
