New dishwasher : Maytag or Bosch
If the Bosch has RackMatic then...
"To accommodate large or oddly shaped dishes, RACKMATIC® allows you to raise or lower the premium upper rack at the touch of a lever (even when full), giving you up to 14" of space on the bottom or 10" on top." (from boschappliances.com)
RackMatic lifts/lowers the upper rack by about 2 inches so that's 12/14 inches in the lower and 10/8 inches in the upper rack.
We've had a few Bosch dishwashers in different houses over the years and I have NEVER done any more than scrape anything.
You basically remove any large lumps of food from plates, bowls etc.
Turn machine on to a normal cycle. Make sure that you use a decent detergent, I find Sun All-in-one Power (Unilever), Finish (reckitt benckiser) and Ecover all extremely effective. Also make sure you keep the machine supplied with salt for the water softener and with Rinse Aid to ensure good streak-free drying and your results will be flawless.
Bosch (and most European machines) have a primarily self-cleaning filter. During the wash the water is sucked horizontally across the filter and through the fine meshes removing all particles. When the machine empties, the water is sucked downwards through the middle of the filter and simply through a large grid that catches anything that's managed to get through. The pump can handle most normal sized food particles and they are simply flushed down the drain and the mesh filters are basically self-cleaned.
There is a wide mesh collar sticking up out of the filter, this prevents any larger items from ever getting into the filter system and they will sit on top of the filter tray at the end of the cycle.
Normally, all you need do is look into the bottom of the machine and you'll find any really big items of food e.g. beans, vegetables, pasta, nuts, etc that was not scraped off the dishes. You'll see these just sitting on the top of the filter system and they can easily be removed by just picking them off. There's no need to actually remove the filter.
The filter can be removed and checked and cleaned every month or so. However, most of the time I don't find anything in it!
Also, I suspect that this system removes more fine food particles than the old US-style disposal systems as there's no risk of fine particles being recirculated through the machine. It also means that the spray arms and jets are extremely unlikely to block up.
See the picture below for the filter centre unit. It sits in the middle of a large fine mesh tray.
One more thing
Remember the water level in the end of the machine will only get to the top of that collar on the top of the filter. There's normally no water flowing down the centre of the filter assembly.
The wash pump sucks water ghrough the fine mesh on the outside - (there are 2 layers of it, one fine and one VERY fine)
When the drain pump starts the water is sucked through that grill on the top and down the centre of the filter. It flows along the mesh and cleans it!
Some machines can even give the filters a reversed wash pump blast with clean water !!
I Love My Bosch
Oh man I love my Bosch. Everything comes out squeaky clean. I have an open floor plan, and it is so very quiet. That is the main reason I purchased it. And I love that the heater is under the tub, not an element inside the dishwasher. That means I can safely put plastics anywhere, yes even on the bottom rack. I use Palmolive gel detergent, Wave Jet rinse aid and get excellent results.
Bosch filter cleaning
I find that the underside of the central filter flange (dark grey, with the blue arrows) is a grease trap - it really needs weekly attention on my machine.
Apart from that, no problems.
