I got my dishwasher!
First, I just want to thank everyone that took the time to give their input and experience.  It was greatly appreciated and I learned a lot from this discussion.  It's great to have a forum like this to share experiences with people all around the world who share a love for appliances as much as I do.
For me it came down to the Bosch 100 Series SHEM3AY56N and the Kenmore Ultra Wash PowerWave 13229.  Both had similar price points.  The Bosch right around $450 and the Kenmore right around $450 as well (after the Sears sale and using a $35 off coupon code).  Sears also had an extra bonus of $150 worth of rewards points paid back in 10 monthly installments, which I can use to buy vacuum bags.  So, after all said and done the Kenmore would end up coming in at $300.
Both offered a stainless tub, but the Bosch had a plastic bottom, while the Kenmore was completely stainless.  Whether or not an extra 25% of stainless steel would make a difference with drying, I'm not sure, but stainless does retain heat better.  Having a stainless bottom should in theory do a better job of keeping the water hot and heating the water faster.
I really liked Bosch's bottom rack.  It seemed very organized.  I took my plates, bowls, and cups down to Lowes to see how everything would fit.  The Bosch had a place for large plates, another for small bowls, another for small plates, and I could fit a few big bowls in between.  However, my family goes through a LOT of cups and the upper rack tines did not fit my needs.  There was a spot for bowls and another row that was too small to fit cups.  On my previous dishwasher (a Kitchenaid), I would use all 5 rows most of the time.  While the Kenmore's middle rack was designed for small bowls it wasn't too wide and I could fit wide cups in there and they wouldn't move around too much.  So, overall, the Kenmore rack was something that fit my family needs a lot better.
Speaking of cups, some of my cups have extra concave bottoms and the Bosch’s lack of a top spray arm had me questioning whether debris pooling on the bottom of cups was something that could end up being a problem.
I really love a front panel countdown display with actual buttons, which both supplied, but the Kenmore's buttons just seemed more sturdy.  While the outside round buttons felt strong on the Bosch, the rectangular buttons closest to the timer felt flimsy to me.  I questioned whether that would be a problem down the line with buttons popping off.
According to the parts manual, the Bosch had the same pump motors as the 800 models!  I'm sure the water pressure would be good (as I’ve seen in dishwasher videos of the 800).  However, after watching a reviewed.com video inside a Kenmore with a PowerWave spray arm and Andrew's video of his Total Coverage arm, I was simply blown away by the water pressure.  A lot of times with a name like PowerWave I would think it was just a gimmick, but the PowerWave truly does live up to its name.  It also helped that Andrew had raved about his Total Coverage spray arm as well.
The Bosch had the best overall cycle options in my opinion.  It had the shortest timed heavy cycle.  It also had the hottest wash and rinse.  With all that good stuff from the Bosch, I just couldn't get over the PowerWave spray arm coupled with a 7.9 gal 1 hour wash cycle and a heated dry option.  That's probably as close as one is going to get to old school wash.
As far as reliability, the truth is, I haven't had great luck with Whirlpool the last decade.  My first Whirlpool lost it's pump and my recent KitchenAid lost it's main board.  On the other hand, I was supposed to get a Bosch instead of the KitchenAid last time, but the Bosch came with a bad pump off the bat, so I got scared off and returned it for the KitchenAid.
Both the Bosch and Kenmore seemed like great washers, especially for their price, but it was one that stuck out to me a little more than the other as a better fit.
I chose the Kenmore Ultra Wash Powerwave 13229!
So, I purchased online from Sears on 4/30 and it was delivered on 5/4.
Here are some of the Pros and cons of the machine after use.
Pros:
1.  The 1 hour wash with heated dry option.  It definitely lives up to its name.  This isn't a quick wash cycle for lightly soiled dishes.  I wish I had a GoPro so that I could see the inside.  It sounds like a lake in there.  It gets the dishes clean and the dishes are steaming hot when its done.  The other night I washed a stainless steel pan I had used to cook burgers in.  It had burnt bits and grease all over it.  After the cycle, there was a quarter inch spec of burnt burger on it. So close!  All the other dishes were grease free, so I'm happy to say it just didn't distribute the grease everywhere else.
2.  The front panel display.  I like the color of digital green numbers on a black panel.  The buttons are textile and responsive.
3.  The black panel.  My last Kitchenaid was stainless and it was absolutely horrible to take care of.  Water spots galore on that front panel.  It was before print shield, so I'm not sure how good stainless is now, but I really like the good ol' black panel.  It's easy to wipe clean.
4.  Slide up detergent dispenser.  They must have finally run out of the old, flip up dispensers, because mine came with the slide up.  It's nice not to have to worry what I put in the front of my bottom rack.
Cons:
1.  Part of the reason that I'm so late with the update is that the first one came with a leaky door on the left side.  When I got the box the left corner of the box was wet.  When I felt the insulation under the door it was wet on the left side.  The door was not closing well either.  So, I believe the dishwasher was layed face down and the pump water that comes in the dishwasher leaked out.  Then once it was place right side up, it leaked out of the door.  I called sears and they remedied the situation and let me know the next dishwasher would be inspected at the warehouse before being shipped to me.
2.  Rinse aid is necessary to get things totally dry.  With my last Kitchenaid, there was no need to use rinse aid.  It had an exhaust fan and prodry option.
 I'm not sure I can truly count this as a con, because this dishwasher has to make a price point and there are more expensive dishwashers that have the turbo dry option if you pay for it.
3.  Super long pots and pans cycle.  We are talking 4 hours folks, if you select heated dry and sanitize.  This used to not bother me, I would just set my old dishwasher on before bed and in the morning I was good-to-go, but the 1 hour wash has spoiled me a bit.  I have to admit it's kinda nice to be able to do a load and get it done before bed if I wish.
So, overall I'm very happy with my purchase.  Thanks for all the help and suggestions!
Here are a few pictures
