Well, I finally had it with the Bosch EcoLogixx 7 - it's taking it more than 4 hours to dry a normal load of towels spun at 1600 rpm (Not overloaded).
It also started to constantly display the clean filter message despite the fact that the filters were definitely clean so, I am assuming the condenser was starting to block up.
The machine was also having issues with black mould in the condensate tank which is just gross.
As we already have vent ducting in place, I decided to stick the Bosch in the shed and think about what to do with it and picked up a Miele T8722 vented dryer. We had a similar machine for years which sadly died due to someone placing sopping wet clothes into it (it was quite elderly). We should have probably just bought the new motor and parts it needed.
This machine seems extremely similar to it, I don't think very much has changed other than the door is bigger and they've added a honeycomb drum and a slightly newer version of the Novotronic controls.
The difference is like night and day! It actually dries clothes, gently and quickly. It had a load of towels done in under an hour, and it didn't seem to overheat them or cause any issues. It just seems to use loads of air circulation to achieve the results.
Yes, it's going to cost a bit more to run, but I seriously couldn't hack waiting over an hour to dry a few shirts.
Also the Bosch was turning absolutely every large size item into a tightly rolled ball and just not drying them at all which was making it nearly impossible to dry bed linen.
Tried the Miele with a couple of fitted sheets last night and they came out 100% perfect, not even slightly tangled.
I just feel perhaps I got the Bosch 'beta test' version of the heatpump machine, but I was loathed to purchase another one.
