sudsmaster
Well, my Waste King has been having occasional jamming issues - it can't tolerate some things like bits of plastic wrap or a single rubber band, so I thought I'd shop around for a replacement. I've had my eye on the top-of-the-line Inskinerator Pro Excel, which my local appliance parts store carries. Never did find out the price...
Then tonite whilst picking up coupon items at Costco, saw that they had a 3/4 HP disposer for the rather low price of $70. "What the heck", I thought. "If it's a POS, then I can just return it any time for a full refund".
Only thing now, is, not sure if it's worth the effort to uninstall the old disposer and install this new one.
The new disposer is a "Titan T-960 Deluxe" from "Joneca Corp." Made in China, of course, but from "USA Design and Technology" ;-). What isn't?
Anyway, it's an attractive enough unit, with a nice silver finish. First thing I noticed out of the box was that the "through" of the drain is plastic, not stainless like the Waste King. This might be quieter but I wonder how durable it will be.
On the box, the following featurs are touted:
Removable splash guard (duh)
Speed mounting system (Insinkerator has it too)
Insulated sound shell - quiet running
"Torque Master grinding system" (whatever that is), "no failure due to rust"...
Laser sharp cutting ring (took a peek and didn't see any lasers, though), "Quick work of food waste".
Balanced turntable, "smooth, vibration free", (the Waste King never seems to vibrate much at all unless it's overloaded).
Stainless steel swivel impellers and cutting components (again, "no failure due to rust"). The Waste King has stainless swivel impellers as well, albeit a bit worn by now.
High rpm, high torque, permanent magnet motor, "fast grinding". Not sure what the Waste King has. Probably a perm magnet motor as well, since it doesn't appear to have brushes.
10 year limited warranty. (Insinkerator is max of 7 years).
I guess I call the local parts dealer and see how much the Insinkerator Pro Excel runs. It's probably a much better machine, with jam sensor, auto-reverse, a third stage of cutting ("undercutter disk") that will reduce drain clogging issues.
