New Kenmore Elite front-load
kenmorepeter01
Active member
Jan 13, 2009
30
Hello...I'm deaf.
This is new Kenmore Elite front load washer
This is the internet to type "www.kenmore.com", then click the blue text "Laundry". Then click "See it action" about new 5 spins (cycle) by video action. I hope you enjoy it!!My friend!
Peter (kenmorepeter01) ;-)
Why bother----
--to put a glass window on any appliance if you can't see through it clearly??? What the hell are they trying to hide?? The top end models that are now made by LG have a light but it's still not clearly visible because of the darned opaque windows.They look great and perform outstandingly but it's not that easy to see the interiors.What a disapointment.
There's a video on YouTube that shows the different tumble actions. It's a European LG.
The different tumbles are shown at 2:30 minutes.
<object width="480" height="385"><param name="movie" value=""></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="" type="application/x-shockwave-flash"allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Alex
it seems they caught on to poor washing results from lower water levels...and this 5 way action compensates for it
time will tell if its a well thought out process
like the issue I have with my frigidaire FL...too little water and the drum rotates too fast, not allowing the clothes to plunge into the water
Amen
Yogitunes, I could not say it better. And I have probably the first Elite machine. I like it and hate it at the same time. Read the posts on this (if you haven't already) early this month regarding this issue of water level.
John
Spiceman.....
I have so far I think got the only solution so far to increase the water level in the frigidaires.....I now have my water up to the window
If I need to I can draw a diagram
Some of
those rythms seems to put a lot stress on the motor by switching directions very fast. I have no idea what there lifetime will be.
I don't see how the "stress factor" would be an issue with a beltless,direct drive,DC motor as it would be with a belt drive front loader.All the newer front loading washers since '95 have a reverse tumble anyway. So,why would these different patterns of tumbling have ANY effect on the machine they run???
Modern FL's
Other machines allow the basket to come to a stop or resting position before changing directions.
I suppose that eliminating the pause would increase the speed of the cleaning. Maybe the wash cycles wont have to be so long.
Something to keep an eye on in the future...
Malcolm
Well During That
Water is being poured over the laundry from above via the paddles. At least that is how it is done on my Miele with it's "scoop and ladle" wash system
Remember how front loaders clean; basically compressing the water/detergent solution through laundry, much as what happens when one washes laundry by hand (or against a brick).
Shorter or eliminating the pauses in theory should increase the washing action, but it could also increase textile wear as well.
Bearings are more stressed by that swing cadence
IMHO Askomiele is right.
Reverse tumbles have a idle time in between. The drum can really stop.
This LG "swing" move doesn't pause. Think of a full 11 KG load swinging back n forth that way during the washboard/friction mode (2:36). When the motor reverses, the drum (then the shaft) is still turning in the opposite way (in other words it has a remarkable opposite inertial torque). Bearings and the shaft itself have to bear some additional stress, wearing them faster.
About reverse tumbles since 1995, is this a typo ?
Even the very first *automatic* frontloaders did have reverse tumble ( vid of a bolt down Constructa K3, 1956). Really the Bendix FLs didn't reverse,
while the italian Philco cousins did ?? Can't believe that after the Launderall there weren't no more reverse tumbles till the 90s ....
No it's not a typo. Chuck was referring to U.S. front loaders since 1995, nothing to do with European products. Although the Launderall and the 20 Westinghouse commercial Laundroma did auto reverse during tumbling.
scoop & ladle ....
is not only a Miele thing. BSH ( Bosch Siemens), various Electrolux alias in many non-jetsystem models, Speed Queen and many others use it.
Miele difference is a multiple speed pattern to enhance both tumbling action and shower effect. Old Novotronics tumble 5.5 seconds @ 55 rpm (best tumble wash action) then slow down to 40 rpm (best showering) for further 5.5 seconds - 4 sec pause ---> reverse tumble
IMHO this miele pattern is a way to walk around the Zanussi-Electrolux Jetsystem patent ...
shocked !!
Now it makes sense why whirlpool decided to produce Duets in Germany despite of costs ... it seems that US producers closed in a storage all the FL know-how and threw away the key..... to the point that the Launderall seems to come from future rather than from the past.
Not to mention the fact that some US HA washers gave some inspiration to some of their european counterparts. Vintage V-Zug Unimatics look close to the Launderall ..... and what about those bolt-down, non spinning Miele 307 that look a bit ... Bendish ?
I have to agree with..
laundromat, why put a window in the door and then cover it up with a dark lens that you can't really see through--what's the point??? I did go see these machines a the local sears store, I do like the look of them, just not the darken-out window. I WANT TO SEE IN!!!
my point exactly
What are these people trying to hide from customers???? Is it the fear of someone looking into the window becoming horrified by seeing racing stripes on your husband's/wife's/partner's underware??Is it that too many customers are wining about too little water use???Whatever their reason,I don't agree.Yes,washer dryers of today,especialy the high end front loaders,can and have become design icons in the laundry room.No longer being hidden out of site from guests or visitors.However,I see no reason to try to hide the interior or it's movements.To me,it looks like they're embarresed to allow anyone to watch it work.Furthermore,why spend all that time and money on the smoked glass and have an interior light??? WTF?????? Maybe we here at AW need to get a petition started and send it to Sears as well as LG,GE and Frigidaire (Electrolux).
Just to be clear---
Yes,the punn was ment to be.Does everyone here remember the early 70's ranges?Do you remember how you still had to open the darn oven doors because the black glass window just didn't cut it? Cakes would fall from the shaking caused by opening the door and so would your soufle's. It wasn't till around the 90's that the range manufacturers decided that a clear,larger see through glass door was more practicle enabling one to actualy look inside to see the food cooking without opening the door---imagine that.i think the smoked or black glass was introduced to hide the splatters and burnt on stins on the insid of the window as well as the dirt on the walls especialy the old cotinuous clean models.
