New Kenmore Elite Set (2002)
blockeight88
Apr 11, 2021
643
Northwest, IN
Good Afternoon,
I am super excited to share I purchased a matching, fully loaded Kenmore Elite set from 2002. I have been searching and searching for a matching set that was fully loaded (preferably one that has more sound deadening material lol. When this set popped up, I couldn't pass it by. I'm hoping the bisque color will grown me. While the set needs a good wipe down, everything looks to be in great condition. If anybody has any additional info on these, I would love to hear. Thanks
Brand: Kenmore
Type: Clothes Washer
Country: USA
Model: 11022994101
Serial: CM0905514
The serial number indicates this product was manufactured in Clyde, OH, February of 2002.
Brand: Kenmore
Type: Clothes Dryer
Country: USA
Model: 11072994100
Serial: MM0902883
The serial number indicates this product was manufactured in Marion, OH, February of 2002.
I'm glad you found the washer and dryer you really want but hope you don't get rid of the 1994 ultra-fabric care machines. You put a lot of time, money, and effort into that washer. If you do get rid of it, make sure you sell it with your money and time in mind.
Both very nice machines
that's a great set. Top of the line models with mechanical timers. You'll be very happy with them.
Thanks. Looks like the end caps really yellowed over the years unless they bisque from day 1. I don’t see many bisque washers and dryers from this era.
The Washer
Does this washer have a 3-Speed Motor on it or a 2-Speed one on it, and does it have the Catalyst System on it?
This washer looks like it’s pretty loaded.
—Charles—
There's no drain/recirculate valve so it isn't a Catalyst.  There are six Speed selections so surely a 3-speed motor.
The 3rd control Rinse Options has One Rinse, 2nd Rinse, Soak and Prewash Only, Soak Only ... if I'm reading it correctly.  Presumably starting at either Auto Soak or Prewash with One Rinse or 2nd Rinse has the machine progress on through the Ultra Clean cycle, Soak Only has it stop at end of the soak period (possibly without draining to allow soaking as long as the user desires), Soak and Prewash Only has it stop at end of the Prewash (with a drain and spin).
Diagrams indicate it should have a variation of the base sound insulation pad (#20).
Wow what a great set!  I love the triple dispensing.  Regarding the softener dispenser, if you select an optional second rinse, I'd be really interested to know if the softener is still flushed in during the first rinse or delayed until the second rinse.
If the plastic side panels have yellowed, you could probably remove most of the yellowing by using the peroxide technique -- it's worked for me on several things.
Enjoy your new machines,
Mark
Reply 10 & 11
The current Kenmore Elite machine I have doesn’t have the triple dispensers or variable water. I think it’s a model below this.
In regards to the side panels, I see they were originally bisque but probably yellowed over the years. The bisque colored ones are NLA but I’ll probably just add white ones.
