New Maytag A102 Washer in Bristol, TN
I hope whoever got this machine will find the dryer that matches it too. It would be an impressive set. That washer was the most basic machine of this design I have ever seen. There was one other model that looked similar and had the timed fill, but only had a switch for hot or warm water. I think that was the one my school had in the cafeteria and used constantly. The timer dial was white too. I sure do remember that model from the past and have had several pass through my hands in the past. I do have a question though, when did Maytag go to the lid using the nylon balls to hold it in place? I remember seeing some old Maytag laundromat machines with the hinged lid. I also would like to know if the AMP model had a reversing motor. Not ever messing with them much, I never paid enough attention to know.
The first TOL Helical from '58, the 141, still had the hinged AMP style lid. It wasn't until the 142 came out in late '58/'59 that the nylon balls made their way to the scene. The lower end Highlanders had the metal hinge I believe from 1957-1965, and the Super Highlanders (300-302/500-502) shared the nylon ball hinge with the higher end models.  I've only had my hands on a 1965 A502 to confirm this without checking the doctrine, but it does make sense in thinking the Super Highlanders would have some features of the TOL, while still relating to the BOL in construction and appearance.
The AMP did not have a reversing motor.  It used a solenoid to shift a lever that tripped a torque spring in the spin shaft and used a clutch to reduce stress on the motor during the transition.
Ben
You're right, Tom!
Ah, time for me to eat crow! Per the doctrine, all washers had the nylon hinges starting with the 02 series (late 64/65).
Glad to hear someone got the washer.
Ben
