I always feel it would be easier to explain these things if I had a presentation board and a pointing stick, haha.
I do have to agree with Henrik and respectfully disagree with John. Yes, the two designs have full theoretical range of motion, but the behavior of the two drive systems are entirely different, which explains why there is such a contrast in the performance of the two.
And yes, vacerator, you are partly correct in that they added a "gearbox", but it is still the same BPM motor used in the Oasis/F&P design. The gearbox is simply there for torque conversion for the same reason it is used in the belt-drive VMW machines.
The VMW belt-drive has only three common agitation profiles: Normal - 360 degree oscillations, Short-strokes for distribution - ~90 degree oscillations, and Long stroke, usually ~2-3 rotations each direction, used primarily in the Bulky/Deep Fill cycle. The speed in which the motor spins to generate the agitation strokes doesn't change, only the duration in which it "pulses" each direction. On the other hand, the Oasis and VMAX designs with the BPM "pancake" motor have quite a few profiles. On a Normal cycle, it will frequently alter its behavior, for example, it can start out with aggressive oscillations at 450 degrees or so, then step down to medium 360 degree osc., then a slower version of 360 degree osc, then a quick short 90 degree, then back up to medium 360. Even if it were to stay at 360 degree agitation the entire time, it can change the behavior of those oscillations by rotating more aggressively or gently. In addition to more variety in its agitation behavior, it can also "sense" the load and adjust accordingly. For example, a light load of typical fabrics will result in gentler agitation, never really going into the aggressive ~360 and ~450 degree, but settling between the medium and gentle strokes. A heavy load with mixed fabrics and things like sweaters and jeans tends to alternate those more vigorous strokes in to help move the load properly, with short gentle strokes throughout to help distribute and keep balance.
Joeypete is right, the belt-drive VMW design is perfect for the traditional fill agitator machines, because the standard back and forth motion throughout the cycle is perfect for that type of washer, but for the HE washplate, it's not quite as effective, and results in lethargic rollover and tangling/balling the load to one side.
In all of this, drive systems aside, the biggest game changer is the addition of a recirculation pump in the flagship Oasis and VMAX machines. The VMW has no recirculation system at all, and in my opinion, a recirc pump makes or breaks an HE top-loader.
The best way to see the difference is just watching videos of the three. As far as parts diagrams, I'll do my best to find each of them and post when I have time.
In regards to the newest design, the VMAX, I finally found a technical education manual that explains exactly how they work and how they differ from its Oasis predecessor. I also have the diagram and a photo for the new machines in question for the thread's original subject.
http://https//s3.amazonaws.com/sm-backend-production-attachments/Job+Aid+-+W10758836+(L-87).pdf
