toomanyhobbies
Member
Hello everyone. I found your site when looking for answers about our 1985 Maytag A612. This came from my wife's grandmother who purchased it new in 1985. She likes it and wants to keep it but I have several issues.
1. I replaced the damper pads with a compatible set from Amazon and used their "silicone compound". I added a little more grease and the washer started creaking/groaning from the pad area. I used some lacquer thinner and removed as much of the grease as I could and that made it better. Am I destined to replace the pads again? Has anyone had luck with the "Compatible" pads or should I get the Whirlpool ones? Which grease do I use? I searched the site and all say to use the grease, but opinions about which grease vary.
2. I have to replace the tub seal every couple years because it wears due to nearly 1/16" of movement in the agitator shaft. I added a couple o-rings above and below the seal and that seems to prolong the replacement interval. I see new shafts will be available soon, but no gear or pin. I have a machinist that can replace the upper bushing. What is the nominal diameter of the seal area? Mine is about 0.732" at this time. I have had no evidence of oil or grease leaking from the top of the transmission.
3. How do I center the tub for the least vibration?
4. What is the proper tension on the 3 springs? Original nut location is long gone.
Thanks for all your help.
K.C.
K.C.
