New products for laundry......
since were on the subject....and I ask because I have a machine with a cold water fill and you can dial in the temp....but realize I can only go as high as 140F degree water temp....my water heater can go as high as 160F....is boiling truely hotter, or just a term for a HOT wash?
what temp is a BOIL wash exactly?.....when I think of boiling water, I think 212F degree, the boiling point of water....do machines go this high?
if I am dyeing jeans, I put the mini washer on top the stove and keep the heat going while the water is at a rolling boil...to me that would be similar to a boil wash
"Perhaps the Spanish variety is less of a problem than the American.
You know how we tend to do things on a grander scale than other countries!"
Please, tell me you're kidding...please.. LOL BTW spanish? Spanish What? LOL
Too funny!
But in case you wasn't...
Crap is an internatioanl thing , especially when it comes to talk of breastfeeders or elderly eating soups, meals or other stuff for tooth-less..
I'm as open to say I had diarrhea just last week and didn't make it to the toilet, crap in my pants, luckily I was in the garage lifting some things and not elsewhere like in the car when it happened..."it happens people, do not do the hypocrites or the shocked ones"...my undies and pants..sparkling clean with a run on Regular, heavy soil level cycle and hot water for undies about 70°c water 158°F , and same cycle with mixed hot/warm for jeans 55°c , 131°F, in the GE filter-flo using Mexican ariel...
I don't think it's the case to make a live demonstration of how my poop gets clean...
But sometimes my cat miss the target into the litter...is cat stuff adaptable for a crap-test? LOL
[this post was last edited: 9/18/2013-10:35]
@ Yogitunes
Hi Martin,
As you said water boils at 212F or 100°C. Old European washing machines (until cca. the 60's) reached the boilin point and kept boiling for a period of time.
Now when such machines aren't available anymore our machines reach 95°C (203F).
That's almost a boiling point, that's why we still used to say "boilwash".
Regarding the wash of diapers usually they were soaked in cold water or if not, they were washed on the longest cycle with the prewash.
Boiling
Always keep in mind the four main variables of good laundering practice: time, *water* temperature, mechanical and chemical action. When you decrease one the others normally must increase to compensate. OTOH when one is increased the others can often decrease.
Boling laundry in the days before mechanical much less automatic washing machines lessened the amount of scrubbing, beating and other manual labour involved on wash day. Stains were pre-treated (such as it was), then items would soak in cool water with perhaps a bit of soda. Next things would be placed into whatever vessel (kitchen copper, boiling pot, etc...) filled with hot soapy water and then boiled for a period of time.
Boiling in soapy water allowed the soap and the action of high temperature to lift off much of the remaining soils/muck from textiles that hadn't been taken care of via soaking. While boiling is hard on fabrics it probably was less than repeated beating, scrubbing and so forth.
The other way of doing things was after soaking was to soap everything up first, then wash in water hot as hands could bear, get as much of that soap out then place in a boiling pot. The boiling acted to help open textile fibers so they would release any remaining soils but also all that soap (which is very difficult to remove) again without all that beating/manual mechanical action.
Then along came sodium perborate and Persil.
Europeans long avoided eau de Javel (chlorine bleach) for textiles fearing it would rot/damage fine fabrics. This is quite true when you consider historically linen and hemp made up a large portion of clothing such as undergarments, bed and table linens, shirts, etc... Cotton would not become widespread until after the North American colonies began exporting the stuff to Europe, and even then with the widespread use of slave labour. Ironically cotton was not unknown in old Europe. It had been brought back from Egypt and other Middle Eastern lands during and after the Crusades. But cotton will not grow in much of Western Europe, and it never occurred to anyone to simply bring back the fiber and spin threads at home.
Anyway, with the advent of perborate bleaching systems housewives could "soak, boil, rinse" and that was it for laundry day. Perborate bleaching systems require temps >140F to become active, and are even better at boil wash temps.
Thus when semi-automatic and later fully automatic washing machines began to appear in Europe they had to do boil washes. Miele amoung others created units that had could be fired by coal or wood for heating.
Women/households that could not afford washing machines (and many could not) went on boiling laundry on ranges or in coppers right up until really after WWII when Europe began to rebuild after the war, but things didn't really take off for most countries until really the 1960's when the "boom" that had been underway in the United States since the 1950's took hold in Europe. Households then started to splash out for "mod cons" including semi and fully automatic washing machines.
The final key to all this was various European countries having to rebuild their power grids after the war and making decisions as to voltage and amperage for domestic use. New construction of housing fully wired, and or the wiring of older homes also helped.
Washing machine manufacturers began to ramp down boil wash temps during the energy crisis of the 1970's. That event also coincided with the discovery of bleach activators (TAED in Euorpe, and NBOS in United States). These chemicals gave "boil wash" results at temps <180F and even allowed perborate bleaches to become active at 100F to 140F range.
P.S. Those Chlorine Bleach Tablets Are *NOT* A New Idea
Milton among other brands have been selling them for years all over Europe. As is often the case with chlorine bleach and Europe these tablets are sold for other purposes than laundry. Milton tabs are sold as "sterilizing" for use when doing baby's bottles and so forth. Much like one finds "eau de Javel" in those little sausage like packets all over France sold in the house cleaner product section, and not laundry.
Bleach
Maytag -
I love chlorine bleach and use it by the truck load for cleaning, I love the smell.
It's just that in the UK - we don't use it for laundry, it's not our culture to do so (I have done a handful of times)
We are identical to Solvenia by sounds of it from a previous poster - We can use bleach as a soak for white garments, but we don't usually add it to the machine.
Bleach
Laundress is absolutely correct, we have the brand Milton (which is a bleach/ sterilising line of products sold for babies), have heard of some using this in laundry although not sold for this.
I've remembered we have a laundry bleach product on the UK market, called ACE laundry bleach it is sold for laundry, few buy it, and I dont think its chlorine - someone may know more.
We do have a million and one laundry additives, which is oxygen bleach - Vanish, Ariel and Ecover and theyre just 3 of them :/
Bleach tabs of Milton are meant for hard surfaces and hard objects... in Italy as for I heard UK and elsewhere there is another similar product which has been advertised for generations (and that very few, would use as they find it useless, at least here) that is called Napisan (germicidal, disinfecting product), once it came in powder only, now even in tablets, and is everything but chlorine, rather oxy bleach indeed (that has higienizing properties) and sterilizing stuff..
Often suggested as a product for baby laundry...it also states has stain remover properties, has also along blends of enzymes infact...and that's the way it is being advertised over here lately, in the hope to raise up the sales of it.
But no bleach in it meant as chlorine...
I never personally heard about Milton bleach tabs used in laundry, but sure someone would...people do every sort of things...[this post was last edited: 9/19/2013-06:37]
Regarding Ace, if it was not chlorine then it was the color safe version bleach from P&G...
Ace Gentile in Italy... Ace Gentle in the UK.
This product was born as a liquid color safe bleach to be used specifically for colors and wollens (Woolmark approved) and also included alternative uses for house cleaning ( the current formula is surfactans+ hydrogen peroxide) the product now includes a wide range of variations, including the powder and the pods...
Powder and pods are more similar to additives in their compositon, actually are sold as additives, and when the liquid is good for wollens the powders are not because of enzymes and other compounds, perborate etc.. (misleading, confusing? Yes it is), in the powder and pods is so kept the "color safe bleaching" purpose but not only, as for the liquid, the powder and pods are good also for whites of course, the powder is a great choice to integrate to a plain marseille soap liquid (surfactans only detergent/s) making of it a complete regular detergent, the powder version includes different blends of enzymes and perborate along...
[this post was last edited: 9/19/2013-06:40]
Sanitising laundry
And another one I have remembered.
Dettol Laundry Disinfectant - This is a ultra new product, only been out about two months.
It's not a bleach at all (I don't know what exactly it is) but our Dettol brand of cleaners - and there's at least 20 variants on the market(pure disinfectant, wipes, sprays, mousses etc)is for sanitizing EVERYTHING
Its marketed purely to disinfect laundry - you put it in place of where the fabric softener would go.
One thing, it smells lovely.
I have linked the one for Australia - the UK one isn't on the UK dettol site yet???
http://www.dettol.com.au/products-for-your-home-laundry-dettol-laundry-rinse
In the past there were not tablets but many powdered chlorine bleaches.
Clorox offered that too.
Way better measuring wise than tablets but of course needed to be put in moving agitating water or diluited and couldn't be automatically dispensed in machines with an automatic chlorine dispenser nor put in the average dispenser cups (meant for sodium hypoclorite)
They are still available for commercial use, and vending 1 load sizec for laundromats.
