Hopefully I will be able to live long enough to see that last a generation end
I'd buy one of those machines if ever my faithful A482 got to the point of beyond repairing.Pierre, I love the video you posted. If everyone was like me every new and used appliance store would look like that. Rows and rows of Heavy Duty EM top load washers.
Happily for now there are still quite a lot of older used top loading washers with central beaters, many in good to great condition to be found. Online sites such as CL, H-Bid and other places do a brisk business in used top loaders.Hopefully I will be able to live long enough to see that last a generation end
just found this video this is what i call a true washer
I noticed that the machine at 2:23 has a serial date of December 2023 (if I'm interpreting it correctly). The narrator says 1) SQs last for "25 or more years with very little maintenance," and that her business "goes through every single machine ... and fully refurbish them and put new parts on them." What new parts are needed on a 2yo SQ?
The machine at 3:17 has serial December 2015, but she says "it's a little bit of a newer model than the other one."
I liked the one with the variable load size water level.
(And, of course, you know I'd perform my "warm rinse" modification on it lol!!)
THAT is how they should make a damned washing machine!
Don't have a dog in this hunt, only top loading washer owns with central beater is vintage Maytag WW.
That being said people should give SQ credit where due if for nothing else their attempts to keep a dying niche appliance alive.
Top loading washing machines with central beaters died out in rest of world for some very good reasons. Outside of USA and perhaps few other places they are difficult to find.
It has been known since early part of prior century that h-axis washers deliver a better result with less wear on fabrics than top loading with central beaters. This is largely behind why early commercial/industrial "steam laundries" out of the gate went with h-axis washers.
Suppose energy regulations for laundry appliances are a debatable point, but never the less they exist and as such days of top loading washers with central beaters are clearly numbered. One suspects in another generation or so top loading washers with central beaters will have largely vanished from North American market.
Newport News, Virginia and surrounding area has lots of US military/defence bases and also housing. There is also shipbuilding, coal and railroads. In short no small amount of multi-family or whatever housing which would have on premises laundry facilties.Judging by how beat up and jabbed in the machine lid is at 2:49 these units may have come out of a very heavy use commercial or hard use on premises environment. It is possible that a new part like a knob, belt, switch, pump, timer, front panel, bleach dispenser, fabric softener dispenser or agitator were needed here and there.
Though it is just a guess as I don't know anything about the history of the machines featured in the video.
You are correct that the machine at 3:17 is from 2015 however minus the normal eco cycle the spacing on the load size selector knob it looks nearly identical to an AWN432 so I could see why see would mistaken it for a model that has been out since at least 2010.
You can transform your current washer into a variable water level model by installing a 206223 water pressure switch that was used on the 512/612/712 washers. It's a direct swap.I liked the one with the variable load size water level.
See Chet, this is what you never seem to understand when you say this constantly.If everyone was like me every new and used appliance store would look like that. Rows and rows of Heavy Duty EM top load washers.
Dan, my A482 Maytag's already got a 4 button water level switch.You can transform your current washer into a variable water level model by installing a 206223 water pressure switch that was used on the 512/612/712 washers. It's a direct swap.
That's cool, however my 4-level settings are fine for me.P/N 206223 is a slider switch that's fully variable between lowest and highest vs. four discrete levels. Manual overfill can be had by holding it at the upper Reset position.
Signed: Goofy Glenn
