seeitrun2006
I recently did a thread on my 7 year Whirlpool DU1055XTSB1 which sounded like it was breaking down and not draining. Well she finally went home to meet the scrape yard.
We purchased a Whirlpool WDF750SAYB3 with a stainless steel interior. It runs for 1:45 minutes on the sensor cycle with hi-temp wash selected. The booklet says the reason for the long run time is the low wattage motor they now use. It is so quiet!!! It has the removable filters you can take out and clean.
It washes the bottom rack first then switches and washes the top rack. It does this all the way thru the cycle. I feel the reason they do this is because it uses so little water to use both spray arms at the same time.
So far it cleans very well!!! I'll check back in a month or so to update how it is working and if it is still quiet. My brother has the same DW. His has been installed for about 3 months. He says it works as good as it did the day he put it in.
We'll see for the long haul!!!
Peace, David
Peace, David
