Newer Speed Queen Comercial Model Top Loaders
laundryshark
Nov 27, 2006
1,224
Cedar Rapids, Iowa
About two weeks ago, we just had new coin-op Speed Queen laundry pairs installed in our apartment building. The washers are top loaders. They have the electronic pushbutton displays. The buttons are nothing more than smooth spots amid a more coarse background. A washer load in our building has jumped from $1 to $1.50. The dryers are the same at $1. I used the washer a few times and noticed, even on a mormal wash load setting, the washer washes, drains partially, refills, washes a few minutes more, and then goes into the drain/spin. Near the end of the drain phaze, a small spray rinse is commenced before the spin really gets going. Then the washer goes into a long full spin and stops. Strange washing configuration, as I really have to watch my detergent/bleach dosing. Although these washers have a good sized tub capacity, I still have to be careful what I load and not over load it. Also, have to manually watch for the correct time to add fabric softener, as I have to get it added right when the second fill has started. These top loaders do not have automatic detergent/bleach/fabric softener dispensers. Only an actual coin insert similar to a vending machine in which one must place in the quarters one at a time (and that takes six quarters for $1.50).--Laundry Shark
Sounds like the machine doesn't do a proper deep rinse with a full tub of fresh water, instead to make it more water efficient it pumps half the sudsy water out and tops up with fresh water doing a dilution wash. I would not add softener to this as you are mixing detergent and softener together, as for adding bleach I don't think a spray rinse before the final spin is sufficient to rinse the clothes properly.
With the importance of energy and water efficiency, top loaders don't work as well when you try to make them use less. Unlike front loaders they can still obtain excellent results using less water and energy, can rinse more times and still use less water than a top loader.
it's been nicknamed the "Gray Water Rinse".....which I really don't see a benefit....if it takes four minutes to fill for a normal wash, drain half and refill, thats two minutes, and then drain completely and spin, spraying water on the load for another two to four minutes before the faster final spin...just seems like it would use more water than a regular full fill wash and rinse......not sure on the exact specs...but this is what the contract/installers are complaining about....and their recommendations is they would not wash their own clothes in one of these...something to think about...
That really feel disgusting! I can't imagine how things can get rinsed enough! And I'm sure that they use more water than any standard front loader of similar capacity
I used a new Maytag (whirlpool made) commercial washer when I was on a cruise ship a couple of weeks ago. The washer only filled 2/3 the way up. Several people complained they had detergent powder all over their clothes at the end of the cycle - and they charge $3 a wash! I was lucky in that I had only filled the washer half way, so my laundry was washed and rinsed okay for a TL washer.
I've used these new Speed Queens and yeah I wasn't impressed either. My clothes didn't feel properly rinsed at all, and I wasn't able to use the machines true capacity since they lowered the water level amounts. It was hardly worth the $1.75 per load I paid and needless to say, I won't be going back to that laundromat. I miss the previous model Speed Queens we used to have that the apartments. The digital models with the wavy vane agitator and a full regular cycle and full capacity usage. This may save water but, many people are going to be very unhappy with the end results of their laundry. And if they're going to have a spray rinse on the last spin, they should program it to happen while the machine is spinning at the top RPM, and at least a full minute long spray.
Xtra $$ for Xtra H20
I wonder if these machines can be programmed to give a traditional cycle for an additional .25. I thought the QUANTUM series machines had that flexibility built in.
Malcolm
In order to keep the top loader alive, they will probably have to do something like this for home units...I'm buying 1 more SQ top loader for storage before 2013. My moms WP only fills 1/2 way in rinse unless the Softener added switch is flipped...talk about wear on clothes.
We have WP TL's at the campground.....2 water levels available.......Large is about 1/2 full, Small is just above the bottom vanes.....next time I am there I will wash a load and take pics of the water levels......I think their 1.50 per load......worthless!
Hmmm
Sounds like a modern picture thread titled hi water level. Post a pic of your modern daily driver at its highest water level setting. FL and TL included.
Malcolm
LOW WATER USE SQ COMMERCIAL WASHERS
Its too bad that WP has tied up the patents on the recirculated spray rinse system that they used on thier TL Resource Saver washers about 10 years ago. That system really worked and actually rinsed the load with 6 separate water changes that automatically adjusted to the amount of clothing in the washer, like a FLer does
If I was going the use these new CSQ for large or real dirty loads I would run the machine through two complete cycles adding FS to the rinse in the second cycles rinse if desired. I do believe that the washers can be reprogramed to give the regular deep rinse, so you could also complain to management and see if they will reprogram them. It would be better even if they raised the price to two dollars per load.
Personally, I would go out of my way not to use a machine that rinses like these Speed Queens do, in fact not only would I not use them unless I MUST, I would make sure the vendor who supplied the machines, the owner/operator of them, AND Speed Queen knew that I and hopefully others are taking the business elsewhere. If people are avoiding using them, the investment in them will take longer to recoup.
Whirlpool's current consumer DDs do the half-fill rinse, which shocks me. Fortunately rinse segments are short as compared to wash times, but that may finally earn these machines their old nick-name of "Shredmore" for real. The rinses use so little water that a label on the inside of the lid recommends diluting fabric softener in a full quart of water BEFORE adding it to the machine. Not happening in my house...
I don't usually like to modify machines, but I am seriously thinking of purchasing one of these 2011 compliant DDs to find out what it takes to modify the wiring to fake-out the half-fill rinse. I am guessing the wash water level switch can be adjusted to provide a full tub at 'High' level for the wash as well.
Gordon
What's everyone so upset about????? LOL
This is what the government wants,(I am being sarcastic of course!!) We should be thankful that we still have the oppurtunity to purchase a Speed Queen T/L washer until 2013. It is absolutely disgraceful that companies are manufacturing washing machines that DO NOT use any water under the guise that they save energy, when in fact, under normal usage, they wind up in landfills in under five or so years!!! I would only assume that Speed Queen would recommend that one use HE detergent in these machines. I still would rather wash in one of these machines than in a front loader that does NOT use any water at all. If I ever have to buy another machine, I will buy a good old fashioned used top loader until these government restrictions are lifted.
Mike
I don't know about a waiting list for machines overall in a marketplace, but we might see increased demand.
Actually if what a couple sales people have told me recently is really true, there is a filament of the U.S. washer market right now that is buying top loaders to replace front loaders they bought 5-10 years ago.
I know of a couple people in that group who bought top loaders in 2010 to replace front loaders that they felt were unsatisfactory. I think my sister would be a willing entrant to the market as well if my brother-in-law would go for it (she has a 2008 LG Steam washer which drives them crazy). I should probably offer them another nice BD set so they can sell their LGs while they still have value?
I think the sheer numbers of top loaders that are disposed of weekly would surprise us all. If even a small part of these are re-directed to rebuilders, there would probably be an ample supply. The smarter thing to do however might be to keep the top loaders from heading toward the recyclers in the first place.
What needs to happen, as I see it anyway, is to change the thinking of the big box stores which have an almost neurotic desire to keep all their haul-aways away from re-users like us (they foolishly think these machines are going to interfere with future sales of new machines) AND we need to re-educate consumers as a whole in the overall energy use (aka carbon footprint) that is involved in every step of replacing a machine. Focusing on just energy and water savings of the new machine alone does not account for nearly all the energies used.
In fact, many believe the most efficient option involving using or replacing a working T/L washer is to use it until it legimately requires replacement, and learn to use it efficiently. Disposing of a machine early often can consume as much overall energy as the new machine saves. People don't think about the energy it takes to source, build, and distribute a new machine, AND in the energy it takes to transport, dispose of, and recycle the old one.
There are a lot of opinions out there on the above, and every time I look at Craigslist I see ads that say "Upgraded to front loaders so we're selling these". If we had a dollar for each household that "upgraded" only to be unhappy later, I wonder how much money we'd have?
I think it would be fascinating to study how many consumers who have machines equipped with a Perm Press cycle, actually use that cycle on a regular basis, and thus estimate how much water and electricity (due to added drying time caused by slow spins) could be saved simply by switching many of those loads to the Regular or Normal cycle. I bet the savings amount would be staggering, and this could be done without making or buying anything...
Gordon
Detergent Issues
Not to drag this way off topic, but if detergents were made even less sudsy, the issue of poor rinsing would fade away. Having to measure detergent with a teaspoon is ridiculous.
Malcolm
One option for these gray water rinse SQ's is to rig the it into a semi-automatic machine......for a one time wash, spin, off
set the timer for a full water level wash and spin.....and then reset again for a full water rinse and spin...
