No start, no power: Maytag LA108
Jan 11, 2026
7
I recently replaced the damper pads & new v-belts on my machine. I was running thru all cycles before I made these repairs, now I cannot get it to run at all? I have noticed that the motor governor tab is fully depressing the motor start switch at all times. Could this be my issue? If so, what is the remedy?
Here is the reply from Gemini AI:
It is great that you've narrowed this down to the 100CD-4 switch. This part is the "heart" of the motor's starting process, and the "depressed button" issue you're seeing is the smoking gun for why the machine is dead.
1. Why the Button is Depressed (The Mechanical Fault)​
In a properly functioning motor at rest, the button on the 100CD-4 should not be depressed.
  • The Mechanism: Inside the motor, there is a centrifugal weight assembly (the "governor"). When the motor is off, these weights should be "in," and a lever should be sitting away from your switch button.
That information is absolutely wrong. It’s backward whenever the motor is at rest. The centrifugal weight assembly is pushing the button on the start switch.
This is the normal rest position. The motor is waiting to be energized, and the centrifugal weight is pushing in on the start switch so that the start winding is engaged. The moment with the power is applied to the motor, as the motor gets up to speed the centrifugal weights fly out in the pressure is released on the motor start switch and allows. Only the run winding to stay in the circuit to keep the motor running.
If the machine is completely dead and won’t fill or run, then start with the lid switch then the timer are really the only two things that control everything other than just the power cord.
John L
John L
Wow, that just goes to show us that "AI" is not always correct in it's very authoritative replies. Much better to rely on those with +50 years experience that know what they are talking about. I will continue my quest to return to service this machine. Thank you all for the replies and suggestions for troubleshooting. Rick
When I Google something, that annoying A.I. answer tops the list with it's BS.
I'd read it, for a laugh.
It's just like talking to a robo caller who doesn't understand or shut up when I'm talking.
I'd sooner give Last Rights to the turd in my toilet before I flush it down.
I refuse to interact with a robot.
AI is the great satan. It will ultimately lead to the end of the human race... Digital armageddon.
Looking at the Big Picture, and comparing it to previous decades, this increasing "Surge" of technology has brought on more crimes, more product issues, and an unattractive change to society.
Yet it's always touted as something wonderful, convenient, and attractive - all propaganda based on marketing sales tactics.
Funny, but society carried on quite fine before all this became a new way of living.
Mind you, I'm not against technology, as long as it doesn't disrupt my world and allows me to maintain control of my life.
I just don't need to be a puppet,... dependent on or relying on some gizmo or product to the point of being obsessed with it.
I'm sure they said similar things, with the horseless carriage, radio, television, automatic washers, etc....
