Norelco Coffee Maker
jakeseacrest
Aug 5, 2006
489
Massachusetts
Hey everyone. I scored a Norelco Dial A Brew HB5-185 from ebay. After one pot of coffee, It started brewing and stopping thus taking about 15 minutes for a pot. I tried vinegar and CLR thinking it may be clogged but nothing. Does anyone know where I can get it fixed? I don't wanna part with it. I emailed the seller, but I told him I would keep it.
Michael,
How comfortable are you with taking things apart?
Nearly all of the reasons for a 15 minute brew cycle come down to only a few, easily fixed reasons.
Here's a few things to check. Some may not apply to that machine - I don't know it personally, but live in a city in which when you drop a glass of water, it's even odds what breaks first - the water or the glass...
1)If a chunk of scale has broken free and lodged in one of the water jets or is partially blocking the water line to or from the heating element, this could cause the problem. Solution:
Check the jets first, then check the lines. If you can't even blow air through them without real effort (disconnected at both ends) then that is probably the problem. If the chunk has lodged withing the heating unit itself, only time and very cautious use of acid and soft tools will get it out. Lots of time. Remember that vinegar attacks aluminium. Oh, could some coffee grounds be blocking something?
2) A heating element may have come loose. Not likely, but worth a check.
3) Thermostats almost never fail this way, but I have heard of weirder things. If one is cycling very fast, then that almost always means either a blockage or
4) Water is not making it out of the heating loop and into the pot. Most systems (sorry, I just don't know yours) use some sort of check valve (often just a little plastic ball) which is very very sensitive to blocking by scale. If the ball is blocked partially open or shut, then the water won't easily get out of the heating element, the thermostat will register a very high temperature and cycle on and off. Check valves are never complicated to find and inspect - they will rattle or when disconnected, permit you to blow in one direction but not at all in the other when working correctly.
5) Stupid one, but, hey - have you checked whether you have a tight electrical connection at every point in the machine?
6)Many machines have a simple device to prevent water from dripping or flowing unless everything is exactly in the right place. Has some part of this system failed?
I imagine you would get tons of good advice specific to your problem if you posted a pic or two.
Good Luck!
I'm thinking electrical because it starts up and makes the brew noises I guess you would call it. Then all is silent for a few minutes, then it clicks and starts again like I had just turned it on. Hmmm...
not electrical
I may be wrong, but that is much more likely to be a result of blockage somewhere in the system (probably a chunk of scale) than electrical. Regardless of make or type, all automatic coffee makers monitor the temperature of the heating element and switch it off when it gets too hot or runs out of water (brewing is done) and then back on again for a little bit at a time to keep the plate warm, cycling regularly.
The good news is that at least a bit of water is getting through. Can you do anything with my suggestions above? Once you know where the blockage is, you can work on improving it.
Me too Jake
I have a new cuisinart that, has the symptoms you described, I am convinced, that the "hose" from the heater to the "water sprinkler" over the basket, has come loose at the heater. The sad thing thing is although i bought it new, it was over a year before I used it the first time. Coincidental that you posted this, I just debated whether to pitch it, or tinker with it. .... It's still in the garage. alr2903
I had this trouble too with a Cuisinart
Mine is (I think) a DCC1200. It has a small paper sack of charcoal to filter the water at the bottom of a long plastic holder which stands in the rear corner of the device. The paper had ruptured and the charcoal granules escaped. I think this is what actually clogged it up. Nothing I did fixed it except repeated brew cycles with only water. Eventually, it unclogged itself and has been working well ever since. (+5 years) I change the filter now at least once a year.
