mechanic2laundr
- Joined
- Feb 15, 2013
- Messages
- 118
Ivan have you ever seen one of these up close??
Yes, I have seen such a car, it's called "Nistru", made it to the city of Chisinau, Moldova is in (MoldavskayaSSR) about 1965-1969. This machine is made of steel top plate, which is welded to the two tanks (washing and centrifuge) that are coated with glass enamel, as the camera pans or in refrigerators.
Clears 2 kg load in 37 liters of water Spin - 2500 rpm. Drive washing - 1450 engine rpm and power of 180 watts, coupled with the activator via a V-belt pulleys. Drive centrifuges - 90 watt motor, 9000 rpm coupled to the centrifuge axis V-belt pulleys in at the lower end of the shaft centrifugal pump is mounted.
In the centrifugal pump delivers water from the tap, which switches the flow of laundry or pressing. Lever is displayed on the top panel and is located between the tanks. Detergent tank closes removable aluminum cap, centrifuge lid is closed by transparent blue plastic.
To store the machine closes common lid. The power cord is removed in a niche on the back and close the lid, drain hose attached to the nipple, which is mounted at the bottom of the back wall. On the front wall mounted panel with knobs.
On the two handles - timers for washing - 6 min. and a rotary switch for drying.
