NOS Hotpoint Washer
Looks like one I have-use it a lot-For a "Builders" machine-works very well.Found it in the "bargain" line at the swop shop several years ago.Did take off the wood grain panel on the top of the console.Like its new "black top" look better-the fake woodgrain was too much.Also adjusted the water level to cover the tops of the agitator vanes.WORKS EVEN BETTER!Has the spiral-ramp agitator.
Built like a tank.
Every one I have ever seen has lasted for years and years of hard service.
Fill flume can easily be modified to spray water INTO the tub to provide a traditional "GE" type spray rinse.
I had one of these briefly in the laundry room here when they played "musical washer." It was a horrible wreck--delicate speed out, back cover missing, cosmetic issues--but still ran seemingly normally on Normal. The problem that doomed it was an incredible reek of mold. I think it had been used with nothing but cold water for some time. (I know the previous laundry room didn't have running hot water.) I tried it to clean it up (using hot water, detergent, and bleach and long periods of agitation), but had no luck. I might have had luck eventually, but another round of musical washers hit...and a reasonably clean WCI Frigidaire became available.
Looks just like the one in the basement of the house I've been renting. I've never used it because it leaks, and also the basement is so nasty that I'd think the clothes were dirtier after washing them down there. There is also the matching dryer, it works but I only used it a couple times for things I hand washed.
One recollection...
But one place I lived had a Hotpoint washer styled like this. I am assuming similar era, and the model was probably pretty similar in features, but might not be this exact model. It was fairly new when I used it (mid 90s), and it seemed like such a quality drop from 60's Kenmore (which was all I'd had experience with). It didn't feel as solid. And I remember wondering about the timer quality given the pauses (rather than going right from wash to drain to spin without the motor shutting down). I now realize, of course, that pauses are necessary on some washer designs. Although, I had zero complaints about how well it washed--although I was less critical back then than I am now.
The funny thing, though, is that by the standards of some washers I've encountered since that time, that Hotpoint seems like a Top Flight product. Funny how that works...
I've read here in the past that the rim flow filter on the Hot Point gets gunked up because you can't get to it easily to clean it (supposed to be self cleaning) like the filter pan on a GE?
I haven't had any problems with gunked up rim filters on mine.Sometimes do find small lint balls-just pick them out.The machine in the video works exactly like the one I have.Not fancy-not embellished-just like a Hoover Convertable--just works and does the job.
the rimflo design does work for the most part, but once filled, its ineffective...and all the water then flows into the outter tub area.....more of a gimmick than anything else....an indexing tub would have made it more effective as odd as that may seem
but this would take all of 60 seconds to change this into a true filter flo....its that moving pan that balls up the lint, and successful at capturing so much...
that standard capacity with longer wash cycle is a whole other beast when it comes to cleaning clothes...
