Oasis/Cabrio owners
supersurgilator
Jun 23, 2007
453
Indiana
I have never seen one of these machines was a load that was over 1/3rd of the basket. WOuld any of you like to fill your machine full and make a vid of it washing? I'm just curious how these machines clean a full load, and didn't know if anyone has ever done it as I always see vids with the machine hardly filled.
This is the AquaSmart - basically the same machine with some modifications. Note: you won't see at lot of turnover at regular playback speed, though. If you download them (say using flashload.net) and play them back at 2x or 3x the original speed, you'll see how even this load of towels turns over.
<object width="480" height="385"><param name="movie" value=""></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Alex
The aquasmart uses WAY more water than the Oasis does. I may have to make some more videos that show the water level at Normal, Sheets/Towels, and Bulky/Bedding cycle.
Also, the AquaSmart can be set to "Conventional Mode" (high water level) on practically all cycles. I'm actually surprised to see those towels being turned over so well on High Efficiency Mode - is was set to HE, wasn't it? I think the Cabrio defaults to a higher fill on Sheets/Towels.
This is on Conventional Mode
