LG's are already in some laudromats
Here I saw some commercial LG FL washers at a laundromat farther north last year. The number of programs is simpler than a home washer.
Bearings used in all FL washer are extremely large for the actual load they see. Some are bigger than the rear axle ball bearing used on a 1960's Ford Falcon car. The reason the bearings fail 99 plus percent of the time is due to a failed water seal. The seal leaks and the bearings corrode and thus fail. Making the bearings even large really adds about zero extra life, it is like gluing a 10 dollar bill to the washer in waste. Using a stainless ball bearing would be better than using a bigger bearing if one wanted a better life.
In commercial washers back in the 1970's, an engineer buddy that worked at one of the majors said some of their commercial washers had a SMALLER spin basket and the same other stuff. This is because the average laundromat user tends to overload washers.
Having one's washer mechanics/mechanism/design in a commercial laundromat is an excellent accelerated life test. The end user does not care about the washer, thus it sees gobs and gobs of abuse. Parts common to both commercial and Home washers that fail early thus are often improved and the home washer thus becomes more robust. All the major washer brands who have sold commercial variants get flak from the commercial buyer, and they tend to be listened top more than a lone home buyer.
Commercial washers may not be beholden to the government water police. The LG 27" frame WM2501HVAS here washes well here, but I about always use the "add extra water button" A normal cycle is about 55 minutes, with prewash too it is 1 hr 13 minutes, a quick wash is 22 minutes. A commercial machine tends to have a shorter cycle than a home machine, thus having one that is in the 30 to 45 minute range is possible.
Historically many small/regular commercial washers are built around the same frame and mechanics of home washers.
LG is who built the compressor in a 5200 BTUH window AC that I use now from Sears/Whirlpool that is 6 years old. A sister AC of the same model ran for 11 years, its LG compressor still worked, its outside aluminum coils were shot.
