Wowies!
Loves it. I think you'll really like this...just a little descaling and the insides will gleam. That porcelain is minty and miles thick--and the spray doodle on the top will preheat the tank before that impeller begins delivering wash-action satisfaction to your plates and dainties. Hooray! And then it will twirl and dry your dishes--does it get any better?
Just like my pank one, only minus the burned-out motor. Hooray!
The Roll-R-Rack flips upside down if you need to put taller things in the bottom...and still works as a top rack even when inverted! Really clever design.
The motor shaft extends (via a bakelite extender thingy) up through a tube in the bottom of the tank. When the impeller runs, it creates a cushion of air that keeps the water from going down the drain. When it stops, everything runs out the slots under the impeller. No irritating carbon-porcelain seals to deal with! Double hooray!
If yours has a timer like mine, see if it doesn't have the terminals needed to run an electric pump off the timer, just in case you're not totally in love with gravity draining. Oh, but what am I saying, your kitchen is right above the basement--do what Robert does, and just run a hose down to a washer standpipe below! ;-)
I can't wait to hear this thing roar to life! You'll pop that Superba KA out of the kitchen so fast its Hydro-Sweep will spin ;-).
