Eddie, 5430706 is the timer for the WO-65 double rinse machine, 5430777 is the timer in your WO-65-2 overflow rinse machine. So no its not the exact replacement, but you can very easily switch the timer motor on the new one.
When I change the temp switch from Hot to Warm,the solenoid on the motor energizes on hot and de-energizes on warm. Is this the sign of the escapement being toast ???
Wait a minute I'm confused, are you saying that the timer motor advances the timer only when you have the water temperature switch on hot?
If the answer to that question is yes then the only thing wrong is someone has the wires mixed up on the timer.
