Old Fashioned Country Style Steak..
norgeway
Apr 28, 2009
9,376
mocksville n c
This is really an ancient recipe...Very popular in the South, this makes a cheap cut of meat"Cube Steak", wonderfully tender with a rich gravy, its not a quick recipe, but its good..first you take some cube steak, however much you want to make,lightly salt it, pepper it, and flour it well..I also add pepper to the flour,heat about 1/4 inch oil in a frying pan, I used a 57 Presto electric for this, brown well on both sides, dip off all but a few tablespoons of the oil, pull the steak to one side and add about 2 tbsp of flour to the remaining oil, stir until brown, add 1 roughly chopped onion, cover with boiling water, cover pan, reduce heat to a low simmer and cook until the gravy is thick and brown, usually an hour or so, depending on how well you browned the steak..
Well...The wierd
Computer posted the pictures twice...Also I add another grind of pepper to the pan before covering, keep the water hot so if it gets too thick you can add a little...
Yep!
For good mashed potatoes, you have to dry the potatoes by shaking them over the heat after they're cooked and drained, then you need to mash them over heat, and then you need to add hot milk for the final whipping.
Any shortcuts, and you'd be better off with instant.
Cubed steak used to be cheap, but here, it ain't so cheap any more!
When I make this, I still pound the cubed steak to further tenderize it, then season, dredge and brown as you do (with a little granulated garlic added). But, then I make the gravy and just lay the steak back in to warm it through since it's already cooked. I like mine to still have a little crispiness when I cut through the top!
And nothing like good, home-made mashed!
Chuck
YEP!
Mark Harman "Lighted Control Dial" makes his that way and its good too, I just make it this way because I like the meat to be falling apart, another good way is something my Aunt Jean does, she flours and browns the steak, then slices a big onion over it and adds 2 cans Hunts tomato sauce and cooks it until done, thats good too.
Im going to
Take it up after while and put it in a Corning Ware Dutch Oven, then tomorrow I will just take it out of the fridge and heat it in the oven a while..I have some fresh green beans, and im going to cook a pot of rice and make biscuits.....mmmm m! LOL
Thanks for this, Hans.   Growing up, my mother would make cube-steak in the Westinghouse fry pan with the broiler lid or put them on the grill.  I've only known them to be tough and leathery so have avoided them since leaving home.
What time you eating tomorrow?  :-)
The country-style steaks look wonderful, Hans! Haven't made them in years.
Mashed potatoes: I cook 3 to 4 pounds of russet or yukon gold potatoes in heavily salted water. Drain well, pour in 8 tablespoons of melted butter, then add heavy cream as needed (usually only a few tablespoons) to get them to the desired consistency. I use the KitchenAid mixer for mashing: Add potatoes and melted butter to bowl, and break them down at low speed using the paddle attachment. Switch to whisk attachment, and whip at medium-high speed, adding cream and a bit more salt if needed.
Ya'll ...
are making me hungry!! LOL. It all sounds mighty tasty! For my version of smashed 'taters: about 4 medium well scrubbed Russets cut up with skin still on (for minerals), 1/2 cup ricotta cheese, 1/4 cup heavy cream, and (optional) 2 cloves finely chopped garlic, then slathered with copious amounts of Real Vermont Cabot Butter when served ... mmmmm mmmmm! And even better with some home-made Sauerkraut alongside!
I've always called this smothered steak. Made a bunch last winter using a cast iron skillet when I bought a 1/4 steer from a friend who is a rancher - organic grass-fed beef, YUM!
My take on mashed potatoes:
Chop a bundle of scallions and simmer in a cup and a half of milk. Boil seven or so Yukon Gold taters with the skin on, drain and remove skins when tender. Mash in the milk/scallion mix with a stick of butter, S&P to taste.
@ 58limited
In my native Northern Ireland your version of mashed potatoes is known as Champ - often served on their own with a good size knob of butter and a glass of milk or even buttermilk.
The potatoes in champ just want to be well mashed not whipped.
I have also seen it done with parsley instead of scallions. Although I dont often have it now, champ is my favourite way to have potatoes
Al
