Old Norge dryer - worth investigating?
Cool Norge dryer
I have never used a vintage Norge Dryer but from what I have heard they do dry really well but they flock the laundryroom in lint and are just a bit quieter than a jet engine going full blast.......PAT COFFEY
They dry well
And have a HUGE drum,the ones I have been around were not noisy..BUT they do have a tendency to blow lint,they operate on a different principle than all other dryers,the air is blown thru the drum rather than being pulled thru,so if the seals are the least bit worn or the vent pipe has too much restriction, you get lint, they are built like tanks.
I thought Norges had the lint filter on the bottom. Did they switch them around at some point? My mom's '67 Wards Signature had the filter on the bottom too, and the Norge in the picture seems to be earlier.
any clue as to the vintage of this old Norge dryer?
Hi Kevin (great name BTW...) I would guess it's mid 60's. I used to have a 1963 Norge dryer that had a similar raised control panel. But mine had the drop down door.
Kevin
Thanks, Kev! I think I prefer drop down doors to swing out doors, but I'll try to check the dryer out. Do you know when Borg-Warner sold off the Norge division?
Is that lint around the door opening?
Nah... Can't be.... ;-)
When I was like 12, a neighbor had one similar to this but more BOL. When you started the machine, the whole cabinet would shudder and creak like an old tractor. I thought it was just too cool how it would blow clothes out of the dryer when you opened the door while running. Those that flew out first were always dry.
Ralph, to answer your question, this one still has the lint filter at the bottom. The door on the top is for access to the pilot light and burner. If it were old enough, there would be a big red movable bar that you could move in an arc from front to back that regulated the burner input. The older dryers had a single operating thermostat, but offered variable heat input that, combined with the high air flow, could keep temperatures very low. Later on they had selections for the heat like Low and Superfast on more basic models then fabric settings like Wash 'n Wear, Shag Rugs, Delicates, etc. The number of settings maxed out at around 7, I think, depending on how much money you paid, but it amounted to two heat input levels and air fluff. The fan was 21 inches in diameter. It was a big disc with the cuts around the perimeter for the blades. The drum was driven from a roller underneath it and the famous Norge Stop'n Dry feature that allowed you to dry without tumbling lifted the drum just enough so that the roller could not drive it. There was a spring-loaded tubular rack that could be placed resting on two baffles at the bottom of the drum for drying stuffed toys, tennis shoes, etc or placed between two baffles at the top of the drum so that items like foundation garments could be draped over it and dried, usually on AIR, without the tumbling that would get all of those clips and hooks caught up where they should not be.
The air entered the drum at the back, just below each vane. The air blew the clothes against the door gasket to the extent that over time, they rubbed the rubber away on the drum side.
When the dryer was redesigned in the mid 60s, the lint filter was moved off the floor.
I don't see any place underneath for the filter, I'm wondering if it's in the door like my 60's Frigidaire. There appears to be an opening at the top the door that makes me think this. SQ uaed an in the door lint filter too.
No, there was a full width flop-down panel at the floor with a small lip-type handle in the center which revealed a rectangular opening in the center of the base where a big rectangular lint screen lived. Only the cheapest, earliest, most basic Norge had what you might call a filter in the door. It was a square opening through the door panel with a filter in it through which the dryer blew the exhaust into the room. This model gave you from the get-go what it took several years of deteriorating seals to achieve with other Norge Dryers.
PRE 1967 NORGE DRYERS
These dryers were very rugged good performing machines, they were easily the most heavily built in terms of drum support and drive strength. I once had an old gas one sitting on my recycle heap and it had been filled with old washer motors, timers water valves etc for recycling at least 150 pounds of stuff. My brother was standing around and I said lets plug it in and see what happens. When started it easily started tumbling that load of scrap metal it sounded like rock crusher with all those washer motors in it, no other home dryer ever built would have been able to tumble that much weight. But as stated by others they did leak air at many points which carried lint with it because the drum was under positive air pressure. Very few other dryers ever did this, the first westinghouse spacemats 1956-1963 also did this. Norge in 1966 went from building the most rugged dryer to the worst dryer in 1967 and they still had the lint problem. These 1967 and on models were the ones that could be very noisy. Norge made positive air flow dryers until about 1980 when they completely redesigned and came out with the 27" machines they eliminated the lint problem but it was never a great dryer, they were always slow. The electric models only had a 4700 watt heater and the gas only had a 18,000 BTU burner, the smallest in any full size domestic dryer. MT continued making this machine until the WP buy out of MT, WP promptly closed out this design and did what should have done 20 years earlier.
Thanks for reminding me. I remember my mom's 50's Norge Timeline did have that access panel up top. The Signature didn't have it, but as I mentioned, it did have the lint screen at the bottom. And it had Stop-n-Dry but Mom never used it.
