kb0nes
Stan,
So you measure 9.5 ohms across the coil? The math would indicate 1300 watts if your line voltage was basically 110 volts.
But, Nichrome wire will increase in resistance a bit when its hot. You may be over estimating power by a couple hundred watts based on a cold resistance measurement.
If you want to get a better idea of the hot resistance try plugging in the heater and letting it warm up. Then with the ohmmeter probes in hand, unplug the heater and measure resistance immediately while the element is still hot. You still need a Kill A Watt just for fun though!
