Older GE P-7 Drop-In Range Stove Oven - $35 (Clover, SC)
Lawrence - wouldn't the seller give you dimensions? If it's 24" wide, 30" tall ..it'll fit sidewise..and depth is your only concern. Do you have a 24" opening? Probably. Do you have 30" width in back? If 36" wide at trunk, does it taper to no more than 30-31"? But I haven't seen the car to measure; moreover, is it ok to lay a stove sideways?
Phil :-[)
